Indeed, plus there's also drag which increases quadratically and is significant at those speeds.
Yeah and power due to drag is v^3 (drag itself is quadratic, but then you get another v due to speed). Energy due to drag per unit distance (t×v) is v^2 (v^2 drag over same distance).
The Raven has 177 kW front motor and a 360 kW rear motor, with 537 kW peak power in theory - in practice probably in the 510 kW range.
If we assume that the Plaid powertrain duplicates the rear motor, that's 177+2*360 = 897 kW theoretical peak power, in practice it will be a bit lower due to the different gearing ratios - let's assume up to ~800 kW peak power can be brought to the wheels, over a broad RPM range - and I'd guess still more than 600 kW at top speed, when the front motor will likely not contribute much an
Gearing does not change peak power, only where the peak power band is relatice to wheel speed.
Dual 3 motors in the back give approximately the same power (177×2 =354, and they can likely do more with a different front/rear power split, no steering angle CV concerns) and likely can also spin the wheels. With an adjusted ratio, that match well with the pack.
The question is whether the Plaid battery pack can output 0.8 MW peak power from a 100 kWh pack: probably not, but if it's a 120-150 kWh pack then possibly yes.
100P ludicrous had pack peak amps of 1,850 (×350? = 650kw) and Motor HP of 680 (×750W/HP = 510kW).
https://www.motortrend.com/news/a-c...sla-model-s-p100d-ludicrous-acceleration-run/
Two rear motors -> better efficiency and thus more output power. Shorter bus bar length in pack (3 style connections) -> less voltage drop -> more power.
This is basically negative power torque vectoring, where generated power from one rear wheel is directly routed to the motor of the other rear wheel, avoiding battery pack charging/discharging loss and heat generation. I'd only expect this to be in play for very short periods when entering and exiting a corner.
I'm not seeing when this would be used. On a turn ,the outside tire gets the most load and is the one you also want to spin faster. So it gets the most work and has the most traction. Inside tire is unloaded and slower. Aero and other drag are still in play, so zero power vs some power gives you turning torque. If accelerating, no reason to regen (less traction), if decelerating no reason to add power (outside wheel). What am I missing?
