Of course the consequence before discharging even starts is that now that I'm on peak time, I'm NOT exporting all solar to the grid. It's instead operating like self consumption with powerwalls sitting at 100% and sun powering house with balance going to grid, so I'm giving up peak export at $0.44 / kwh. Now if the event doesn't result in a good amount of discharge, I could end up being net negative on the revenue.
Here is the PG&E VPP Fleet Home data that I collected for the event that just concluded at 10 minute intervals The peak was at 6:00pm with 18,867 kW with an estimated 45.1 MWh delivered during the event with 2,792 homes. At one point the homes was listed at 2,793 and at the end it was 2,791. My two Powerwalls discharged 23.2 kWh and end at 9%.
According to the Tesla 5 minute interval data, 21.6 kWh went to the grid over the 3 hours. That is a combination of solar and Powerwall discharge.How much of the 23.2 went to the grid?
Didn't quite make it to 8 pm. I hit 5% (started at 100%) at 7:57pm. Oddly enough as it got lower the draw increased reaching about 14.5 kw (3 pws) right as it hit 5%.
PWs discharged a total of 35.4 kWh during the event with 29.6 kWh discharged to the grid for a total of $59.17. My model extracts this and figures it out for me. The app won't tell you how much of the discharge was for the house and for the grid numerically.
I've grand totaled just over $100 between the two events. The first event was cut short for me because the power went out in the neighborhood with 1 hour to go.
That doesn't really matter as the VPP compensation is based on the Powerwall discharge during the event minus the average from the 10 previous weekdays during the same time period.
VPP pays on the extra discharge during the event from the baseline. The baseline is the average discharge for the same period for the last 10 weekdays or last 4 weekend days if the event is on the weekend.What does the mean the average from the previous 10 weekdays. Average of what? Are you saying I didn't make $60 from the 30 kwh I discharged to the grid today from my powerwalls from 5 to 8 pm?
If you normally only discharged 15 kWh from 5:00-8:00pm and discharged 45 kWh during the event then the difference is 30 kWh and that's worth $60.
Discharge ro the grid versus discharge to the house is not relevant. VPP is just about discharge from the Powerwalls for the event period versus the baseline period.I don't discharge anything to the grid from the powerwalls ever. The only two times have been these two events.
It looks like Tesla VPP uses the same avg that ohmconnect uses. For weekdays thats the average of NET usage over last 10 days, event days excluded.I don't discharge anything to the grid from the powerwalls ever. The only two times have been these two events.
The danger of using all your PW juice during these events is that you have nothing left if the power really goes out which there is a higher likely hood of during flex alerts.
If there was a real danger of rolling blackouts to prevent grid collapse then I likely would not participate, but this hasn't happened and really isn't a high risk factor as CAISO has been showing lots of reserves. Those reserves have higher pollution and higher cost, but not as high as the VPP pays currently.I'm always surprised people are willing to discharge down to < 10% for these events and will have no battery left if a real power outage hits after 8pm. I'll just sit with my reserve at 60% right now during the summer and miss out on the $~50 per event since I'd feel bad and get the wife complaint that "We have ESS and no power now and you used up all the batteries for that!?!?!"
This actually does not seem to be the case. See @Redhill_qik's comment above yours.It looks like Tesla VPP uses the same avg that ohmconnect uses. For weekdays thats the average of NET usage over last 10 days, event days excluded.
The net usage includes discharge to the grid from your solar, which happens if you use your pw to power your home during peak hours while the sun is out.
From my Tesla App:This actually does not seem to be the case. See @Redhill_qik's comment above yours.
Although the math is the same, Tesla has opted to use submetering of the Powerwall output. This means solar has no impact (other than reducing the maximum export rate of the Powerwalls). Also, home usage will not count against the amount.
The 10 weekdays if the event is a weekday is correct for Tesla VPP, but the baseline average is only for the Powerwall and your house load and solar are not a factor.It looks like Tesla VPP uses the same avg that ohmconnect uses. For weekdays thats the average of NET usage over last 10 days, event days excluded.
Agreed that it is all about the baseline and since a lot of people have configured their Powerwalls to cover all of the Peak period or are using the Export Everything option then their baseline will be high. If your average Powerwall discharge was -10 kWh during the event hours than that is your baseline.So your baseline could be negative to start out with and not just zero. For example, I know someone with a roughly 9kw system and their baseline avg for this last event was -5.kWh because of the solar power sent to the grid between 5-8pm on avg. So if during the event they sent 12kWh total their net profit would be 12-5 = 7 7x2 = $14.
It's all about the baseline.
