Array
[tesla] => Array
[response] => Array
[id] => 00000000000000000
[user_id] => 000000
[vehicle_id] => 0000000000
[vin] => ?????????????????
[display_name] => ??????????
[option_codes] => AD15,MDL3,PBSB,RENA,BT37,ID3W,RF3G,S3PB,DRLH,DV2W,W39B,APF0,COUS,BC3B,CH07,PC30,FC3P,FG31,GLFR,HL31,HM31,IL31,LTPB,MR31,FM3B,RS3H,SA3P,STCP,SC04,SU3C,T3CA,TW00,TM00,UT3P,WR00,AU3P,APH3,AF00,ZCST,MI00,CDM0
[color] =>
[tokens] => Array
[0] => ????????????????
[state] => online
[in_service] =>
[id_s] => ?????????????????
[calendar_enabled] => 1
[api_version] => 6
[backseat_token] =>
[backseat_token_updated_at] =>
[charge_state] => Array
[battery_heater_on] =>
[battery_level] => 85
[battery_range] => 260.7
[charge_current_request] => 10
[charge_current_request_max] => 10
[charge_enable_request] => 1
[charge_energy_added] => 0
[charge_limit_soc] => 65
[charge_limit_soc_max] => 100
[charge_limit_soc_min] => 50
[charge_limit_soc_std] => 90
[charge_miles_added_ideal] => 0
[charge_miles_added_rated] => 0
[charge_port_cold_weather_mode] =>
[charge_port_door_open] => 1
[charge_port_latch] => Engaged
[charge_rate] => 0
[charge_to_max_range] =>
[charger_actual_current] => 0
[charger_phases] =>
[charger_pilot_current] => 10
[charger_power] => 0
[charger_voltage] => 1
[charging_state] => Complete
[conn_charge_cable] => IEC
[est_battery_range] => 158.74
[fast_charger_brand] => <invalid>
[fast_charger_present] =>
[fast_charger_type] => MCSingleWireCAN
[ideal_battery_range] => 260.7
[managed_charging_active] =>
[managed_charging_start_time] =>
[managed_charging_user_canceled] =>
[max_range_charge_counter] => 0
[minutes_to_full_charge] => 0
[not_enough_power_to_heat] =>
[scheduled_charging_pending] =>
[scheduled_charging_start_time] =>
[time_to_full_charge] => 0
[timestamp] => 1573336784232
[trip_charging] =>
[usable_battery_level] => 84
[user_charge_enable_request] =>
[climate_state] => Array
[battery_heater] =>
[battery_heater_no_power] =>
[climate_keeper_mode] => off
[defrost_mode] => 0
[driver_temp_setting] => 21
[fan_status] => 0
[inside_temp] => 8.5
[is_auto_conditioning_on] =>
[is_climate_on] =>
[is_front_defroster_on] =>
[is_preconditioning] =>
[is_rear_defroster_on] =>
[left_temp_direction] => 0
[max_avail_temp] => 28
[min_avail_temp] => 15
[outside_temp] => 7
[passenger_temp_setting] => 21
[remote_heater_control_enabled] =>
[right_temp_direction] => 0
[seat_heater_left] => 0
[seat_heater_rear_center] => 0
[seat_heater_rear_left] => 0
[seat_heater_rear_right] => 0
[seat_heater_right] => 0
[side_mirror_heaters] =>
[smart_preconditioning] =>
[wiper_blade_heater] =>
[drive_state] => Array
[gps_as_of] => 1573321179
=> 152
[latitude] => 00.000000
[longitude] => 00.000000
[native_latitude] => 00.000000
[native_location_supported] => 1
[native_longitude] => 00.000000
[native_type] => wgs
[power] => 0
[shift_state] =>
[speed] =>
[gui_settings] => Array
[gui_24_hour_time] => 1
[gui_charge_rate_units] => kW
[gui_distance_units] => mi/hr
[gui_range_display] => Rated
[gui_temperature_units] => C
[show_range_units] =>
[vehicle_config] => Array
[can_accept_navigation_requests] => 1
[can_actuate_trunks] => 1
[car_special_type] => base
[car_type] => model3
[charge_port_type] => CCS
[eu_vehicle] => 1
[exterior_color] => Colour
[has_air_suspension] =>
[has_ludicrous_mode] =>
[key_version] => 2
[motorized_charge_port] => 1
[plg] =>
[rear_seat_heaters] => 1
[rear_seat_type] =>
[rhd] => 1
[roof_color] => Glass
[seat_type] =>
[spoiler_type] => Passive
[sun_roof_installed] =>
[third_row_seats] => <invalid>
[use_range_badging] => 1
[wheel_type] => Stiletto20
[vehicle_state] => Array
[api_version] => 6
[autopark_state_v2] => standby
[autopark_style] => dead_man
[calendar_supported] => 1
[car_version] => 2019.40.1.0 69g3a45
[center_display_state] => 0
[df] => 0
[dr] => 0
[fd_window] => 0
[fp_window] => 0
[ft] => 0
[is_user_present] =>
[last_autopark_error] => no_error
[locked] => 1
[media_state] => Array
[remote_control_enabled] => 1
[notifications_supported] => 1
[odometer] => 123.163918
[parsed_calendar_supported] => 1
[pf] => 0
[pr] => 0
[rd_window] => 0
[remote_start] =>
[remote_start_enabled] => 1
[remote_start_supported] => 1
[rp_window] => 0
[rt] => 0
[sentry_mode] =>
[sentry_mode_available] => 1
[smart_summon_available] =>
[software_update] => Array
[download_perc] => 0
[expected_duration_sec] => 2700
[install_perc] => 100
[status] =>
[version] =>
[speed_limit_mode] => Array
[active] =>
[current_limit_mph] => 80
[max_limit_mph] => 90
[min_limit_mph] => 50
[pin_code_set] => 1
[summon_standby_mode_enabled] =>
[valet_mode] =>
[valet_pin_needed] => 1
[vehicle_name] => ??????????
Array
[tesla] => Array
[response] => Array
[0] => Array
[color] =>
[tokens] => Array
[state] => online
[in_service] =>
[api_version] => 6
[backseat_token] =>
[count] => 1
