Discussed here:
Encrypt API tokens by adriankumpf · Pull Request #2360 · teslamate-org/teslamate
With this PR, API tokens are stored in encrypted form in the database. During the database migration a randomly generated key will be used encrypt the tokens if no ENCRYPTION_KEY environment variab...github.com
Does that mean using Teslamate is dangerous?
Put it in another way, does that mean it would actually be better to run it on a local machine (such as pi or a NAS) without exposing the interface to the internet (hopefully)In a sense, yes. If you host it on a shared hosting service and let other people access it (eg, via weak passwords), it is pretty dangerous. But that is true in a pretty general sense too. Its no more dangerous than any other similar software would be if used without some caution.
Put another way, are cars dangerous? Is AutoPilot dangerous? Yes, in both cases, if some caution isn't taken.
I use Tesla mate because its battery drain is negligible, especially compared to some others that I've used in the past. It is great about getting accurate data without waking the car.Hi folks, I am new at this thread and teslamate. Though the car hasn't arrived yet but gathering knowledge about it. I got couple of questions regarding it -
* How much extra battery drain do you guys see for using teslamate? Is the battery loss negligible or thats something should keep in mind?
* Anyone uses teslamate with home assistant? What type of automation you use if yes? I am thinking about creating some geo based automation for safety. Please share any experience on it.
Cheers
Cheers
That's the default setting these days so there won't be any additional drain at all with a standard Teslamate install.> How much extra battery drain do you guys see for using teslamate?
If you enable ‘streaming API‘ in the settings, teslamate just monitors data being generated and reported by the car to the Tesla cloud. It won’t put any additional load/activity on the car itself.
You won't see anything until Tesla has added the actual car to you account at delivery handoverHi all, I'm expecting my Model 3 LR in the next four weeks and have got in early to try and set up TeslaMate on my QNAP via Docker. It's up and running however I'm not sure if I should be seeing more than I am, especially as I don't even have the car yet
I went ahead and used the Auth for Tesla app to generate the Access and Refresh tokens and have this 'blankish' screen
and the settings screen shows
Should I be seeing anything else at this stage or is there something I should do in Grafana? I'm assuming that TeslaMate has picked up the vehicle API key via the Access tokens?
Thanks in advance,
Cam
Thanks for that, what’s another monthYou won't see anything until Tesla has added the actual car to you account at delivery handover
No, the data isn't stored anywhere. Teslamate captures it from the real time stream from Tesla.If one does lose data I wish there was a way to tell Teslamate to re-download data from a specific date. Is this possible?
Interesting. I figured the data came from a server at Tesla.No, the data isn't stored anywhere. Teslamate captures it from the real time stream from Tesla.
It does. But the data is streamed in real time. Teslamate - and all the other apps - tap into this stream and download the data. While the data may well be stored by Tesla - no doubt for nefarious purposesInteresting. I figured the data came from a server at Tesla.
