supratachophobia
I can understand your confusion, but thusfar, wk057 has not stated which pack variation the cells he put under the testing he is discussing came from.
here's what wk057 said in the first post of this thread as to the origin of the cells he did the month long test on,
"I presently have had roughly 20 pairs of cells from Tesla's "85" kWh pack running 24/7 doing various cycle tests in various conditions. (Eventually I'll be posting detailed data from these tests, but I want to give them significant run times.) These cells were from a pack that had less than 1000 miles (or less than 5 charge cycles) on it, and arrived to me charged to roughly 50% (perfect for storage/shipment)."
understandably, you may have confused wk057's discussion of Panasonic cells with an "A" or "B" designation in comment #48 of this thread with Tesla packs "A" and "B."
- - - Updated - - -
okay, so at 60 mph the Model S has roughly 300 miles of range. so, if I'm not misunderstanding you, 10% less weight would mean 0.6 kWh change in energy needed to travel at that speed per hour... or 3 kWh for the total time to use the vehicle's range capacity. I don't know the source of your data, but it is quite consistent with the point I'm making.
what's more, when you consider that the EPA range is not determined by traveling at 60 mph, but rather by a 5 cycle test, where the cycles average 8.8 miles of length and 11 stops, clearly it is extremely plausible, a 10% weight reduction could easily allow for 4 kWh reduction in battery size to the vehicle while maintaining the 265 mile range.
I think he mentions the source in his other threads, but I could be wrong. And no, I was not confused by the Panasonic numbers.
