From my experience, Tesla does not use a secure overwrite. I recovered the full capacity of the drive using this method here with Recuva:My Tesla's Dashcam let me down when I needed it the most. While waiting at a traffic light, my car was rear-ended, it's not safe to stay in the car and I had to wait outside for help. I assumed that the dashcam would have automatically saved the video footage of the incident, but when I checked a few hours later, the footage was already overwritten. Although I tried to recover the deleted data from my USB drive, I was unsuccessful because the car used a secure method to overwrite everything. I understand the importance of privacy,but users should have the option to choose how long the videos are kept before they are overwritten.
Most aftermarket dashcams have function for impact sensing. if there is impact the dashcam will automatically lock the current and/or previous files without overwriting them.Did you click on the Icon, or did you use your horn, to save the last 10 minutes of recording?
Otherwise could please explain what you mean by "automatically saved the video footage".
Model Y Owner's Manual Auto: Dashcam automatically saves a recording to the USB drive when Model Y detects a safety-critical event, such as a collision or airbag deployment.Did you click on the Icon, or did you use your horn, to save the last 10 minutes of recording?
Thank you for the information, I tried again with Recuva, but still no luck. it may be because sentry mode was enabled so the data overwritten.From my experience, Tesla does not use a secure overwrite. I recovered the full capacity of the drive using this method here with Recuva:
Dashcam in Auto
Basically do a deep scan, and selectively recover files in large increments (to avoid having to recover every file) until you find the right one. They are relatively in order, but it loops back. Make sure to recover to a different drive (not the USB drive with the raw footage) to avoid overwriting anything.
I don't use Sentry mode, so that may make a difference. Yes, if Sentry mode records events, it can overwrite the dashcam, plus it takes up disk space that otherwise could have been used for the loop. For my 128GB card (same size as drive that comes with car), I calculated it could hold a max of about 13 hours of footage. There was about 3300 clips Recuva found with the deep scan (not sure how many you found). If your car was parked in a lot for a while, and if you had a bunch of Sentry footage even before the event, I can totally see it take up the space.Thank you for the information, I tried again with Recuva, but still no luck. it may be because sentry mode was enabled so the data overwritten.
for those trying to find lost data: I tested multiple software TestDisk recovered more files than others and it's free.
Also in the manual: "NOTE: Several factors determine whether or not Dashcam automatically saves a recording of a safety- critical event (for example, amount of force, whether or not airbags deployed, etc.). Do not rely on Dashcam to automatically record video of all safety- critical events."Model Y Owner's Manual Auto: Dashcam automatically saves a recording to the USB drive when Model Y detects a safety-critical event, such as a collision or airbag deployment.
I did set it to Auto.
I didn't do anything, the car detected impact, the screen shows a lot of critical error warnings messages, and I worry about another impact, so I grabbed my daughter and stay away from the car
Does the Honk still save the clip even dashcam set to auto?Horn honk is vital here - even if you're stressed out and can't remember how to go in and save a clip, you'll always remember that the horn does it.
I hear you though, this is like when you try to fumble to catch an important pic with your iPhone and by the time you've got the camera open, the moment has passed. (Or the camera glitches out only when you need it most)
Either way should work.Don't you just have to tap the icon at the top of the screen to save same as a horn honk?
is there a way to hardwire an aftermarket dashcam? i have an extra one from the last car I sold and I want to install this on my MY.aftermarket dashcam is the way to go!
