OK. We've got two Teslas in the household: A 2018 M3 LR RWD, which very definitely doesn't have a heat pump, and a 2021 MY LR, which does.
No question: The only ways on the 2018 M3 to get heat into the cabin is by:
- Running an honest-to-golly resistive heater that warms the air. Which sucks electrical energy from the battery.
- Taking warm "refrigerant" that runs through the motors and battery and, using that with a heat exchanger, warms the air going to the cabin.
One can tell that it's a cold day in the U.S. Northeast when the W-hr/mile on the 2018 M3 gets into the 350-400 W-hr/mile range. In the summer, it's more like 250 W-hr/mile. Winter time range goes down quite a bit as a result.
Now, let's talk about the 2021 MY. It does have a heat pump. Around here, what a heat pump fundamentally does is runs (in the winter) cold air through the radiator in the nose of the car. Good old gaseous, Freon-style refrigerant that is guaranteed colder than the outside cold air gets
warmed up by the cold air passing through this radiator. This gas exiting this radiator has been warmed up a bit; it's either at the temperature of the external air or somewhat colder than the exterior air. The air leaving the nose radiator in the front of the car comes out
colder than what went into said radiator. Implying that heat was extracted from the outside air.
This "warmed up" gas (pretty good for a gas that might be sitting at -20F) then goes into a compressor and comes out as a
liquid that... is hot. Hotter than the cabin air, anyway. This is, by the way, the magic of the heat of evaporation of a material. Compress a gas into a liquid and it gets hotter; in the reverse direction, run a hot liquid through a nozzle, with a gas coming out, and the temperature of the gas is much colder than the liquid.
In any case, this hot liquid than passes through a second radiator. The source of air for this radiator is either the outside air or, if recirc is on, the cabin air. In any case, the air coming out of this radiator is now
warm, while, at the same time, the liquid Freon-style refrigerant coming out of this radiator is cooled to be, say, warm. The warm air warms the cabin and defrosts the front and side windows.
One then runs the warm refrigerant through an expansion nozzle, liquid in, gas out - and the gas coming out will be dead cold. Much colder than than the outside air.
OK, so I may have lied a bit. It's possible that there's actually a total of
three radiators: One in the nose, with Freon-style refrigerant; an intermediate one that has Freon-style refrigerant going to/from the compressor/nozzle and the nose radiator on one side, and the car coolant on the other; and a final radiator that has car coolant on one side and cabin air on the other.
But! The main point is that one is moving heat energy from (the admittedly frigid) air outside the car to the air in the cabin by playing silly buggers with refrigerant, refrigerant compressors, and nozzles. As one learns in Thermo 101 (for non mechanical engineers, don't-cha-know) this is a
much more efficient process to heat air than by playing around with an electric, toaster-oven-style heater.
And it shows. In the same cold weather that's got my 2018 M3 doing 350 W-hr/mile, the 2021 MY hits around 300 W-hr/mile for the first couple of minutes of driving, then drops to 280 W-hr/mile. And stays there. In the summer, the MY gets around 250-270 W-hr/mile, so, there is a bit of a hit, but the range reduction is vastly less than with the older car.
So: This is not a drill. This is real data. Tesla says its got a heat pump in there in the newer cars. The data supports that.
