DC Doc
Hopefully this DYI is helpful when the rear door handle will not present. It is very common for the white wire on the microswitch to break.
Here's one more way the door handle unit can fail and not present. First some background. Model S 85 delivered March 2013. Bought used in March 2017 just out of warranty. Right rear door handle assembly replaced at service center July 2017 and I kept the old unit sans paddle gear. Common paddle gear failure.
The paddle gear problem is well known and I have been able to fix it with a new paddle gear from my local Tesla service center May 2018 (left side rear.) Within a couple months of that fix the left rear door handle again failed to present. Upon removal I found the gear on the motor that drives the paddle gear had cracked along its entire length, the paddle gear was intact. I had the old door handle unit from the other side that had been replaced last year so pulled the gear off the old motor and slid it onto the motor from the left side. (OK, did need a little prying to remove and then tapped on with a hammer. The broken gear made a good tool to tap it on the last quarter inch.) Note that these motors turn opposite directions - the left and right units are mirror copies of each other so putting a right side motor on the left side doesn't work.
Unlike the paddle gear, the drive gear alone is not a part that Tesla will provide. I checked. I am posting this as an additional failure mode, but one that involves failure to present the handle. Oddly, the crack is along the thickest part of the gear that aligns with the flat on the motor shaft.
