CVT would/could also work but they relatively suck from efficiency point of view.
It's usefulnes comes from alowing ICE to stay close to optimal RPM. What is lost in CVT is more than compensated by ICE being a bit more efficient.
Electric motor has much wider "optimal" RPM range hence much less profit from holding its RPM almost unchanged.
Dual speed transmission would be a bit less efficient than a reduction gearbox because of some additional always rotating parts (gears, clutches, bearings) but if it would allow electric motor to spin faster at lower speeds (same power at higer RPM means lower current and hence lower heatlosses) and also lower RPM at higer speeds - it would enable higher output power at speeds above ~80 mph.
Look at power/speed diagram:
MSP can output its maximum power between 42 mph and 72 mph, a 30 mph wide "max power window". Below 42 and over 72mph its max power (and efficiency!) drops.
A dual speed version could double the width of this "maximum power window" from 30 to 60mph - say from 27 mph to 87 mph.
Now when you go faster than ~72 mph, motor efficiency drops. With a dual gear setup it would retain maximum efficiency up to 87mph.
Now when you go slower than ~42 mph, the motor does not work optimaly. With a dualratio transmision it would work optimaly already at 27 mph.
I would not be shocked if future models "reintroduce" multiple ratio gearbox. Adequately engineered of couse.
The Lexus Rx450h has that I think
Lexus / Prius CVT is completely different from a CVT in an Audi.
Audi's CVT is a "real" CVT - it has one input and one output shaft, with a mechanism (belt) to transfer/multiply torque between them in "infinite" number of different ratios or steps. This could work in a EV but because of poor efficiency don't hold your breath
CVT in Lexus / Prius / Volt / hybrids has two inputs and one output - it is basicaly a torque summation device. It needs two indepentant motors to work and is as such unusable in a "single motor EV".
