ScoobyDoo82
The AP follow numbers are not actually measured in car lengths. They are just arbitrary numbers similar to a stereo volume knob. The number doesn’t reflect any measure of length or time. It’s simply a setting to indicate more (or less) space from the number before (or after) whatever you have AP set at. Setting your AP to “2” will keep you actually a little bit more distanced from the vehicle ahead of you than only 2 “car lengths”.Can I just say that using car lengths as the metric is stupid? Following distance should be based on time not distance.
It should be a measure of your reaction time, and ability to stop before plowing into what is in front of you. See the recent crash in the tunnel, where people behind were choosing a poor follow distance.
If you use time then you don't need to adjust it for different speeds, and you would automatically be able to follow closely at low speeds, because 200ms of time is not very much pavement at 10 mph.
For someone driving aggressively and video game caliber reflexes, 200ms would be OK. If you are driving casual, let's bump that up and give you 500ms of reaction time. If you are on TACC, let's bump it up to 1000ms, because you want some leeway.
Am I asking too much to have sane measurement units?
I mean what actually is a “car length”? 8ft, 10.8ft, 12ft? It’s subjective.
I’ve had my AP set at “2” for as long as I’ve had Tesla’s.. the following distance has always varied.
