Having recently signed up to Octopus Go I have just started using timed charging to take advantage of the lower rate between 00.30 and 04.30. The problem is though, that whenever the timed charging starts, it only ever runs at 16A, not the 32A I would normally get if I just plugged the car into the charger without the timer being set. This has remained the case all the way through the 4 hour period, charging at around 11mph compared to a typical 23mph my car normally reports.
My car (MS 70D 2015) was recently updated to 2020.48.12.1 but I haven't found reports of others with this particular update having a similar problem.
The charger (a Wallbox) happily delivers 32A if I just plug it straight into my car without any timing restriction and also delivers 32A (27mph) on a timed cycle if my wife's ID.3 is connected with the timer set (using the Wallbox app to manage the timing).
I have tried using my car for the timing with 'start charging from...' set but the outcome is the same. While the car is charging at 16A the option to increase the charge rate above 16A is greyed out and just shows 16/16 available. Before the timer kicks in though, and with the cable plugged in it shows 0/32 and 'ready to charge'.
To add insult to injury, the charger app shows 32A being delivered (or rather, made available) but again the car only reports 16A. The voltage is fine at up to 244v and there are no settings in the timer set to deliver reduced power, so I am not sure if there is anything else to check?
Do you think this is something that might be resolved in a further update (as happened previously) or should I be reporting this to Tesla? (I am out of warranty by the way, so no doubt I would be charged to investigate the problem).
Failing that, any other suggestions?
(I have tried a couple of re-boots, following the software update)
