Here's a couple mistakes I made trying to remove the windows so I'll share and you don't have to make it.
First there is the nut on the front attachment point. Shown in the pic below, never take that nut off. loosen it and your window will come up, the nut grips the rubber onto the window.
Second the rear attachment point is released buy gently pressing the button with a screw driver.
This is the side you push, where I have shown the screwdriver.
I'm also including a picture of the back side to more clearly show where the button is.
When placing the glass back in I like to support the plastic holder as I lock the window back on the tab. That should help prevent strain on the connector and it breaking the off the cable.
Here is a video for the regulator replacement that is not from me.
