I just bought a used M3 with 20k miles. I had it inspected and was told the rear wheel tread was down to the tire tread bar, which meant I had about 10-15k miles left before needing a change.
I brought it to a tire store today to have the car aligned because it was veering to the right. They did the alignment, then told me I needed to change the tires immediately because they were down to the tread bar.
I called back the inspection place, who'd told me the tires didn't need immediate replacement, and they said they'd never tell me what to do or not do re tires. But also said I probably still have about 20% use left.
They also said I shouldn't have had the car aligned if I was going to get new tires, because the front tires would be rotated to the back and the new tires would be put in their place (in the front). This, they said, would throw off the alignment and I'd need to redo it. But at the tire place, they said I wouldn't have to re-align with new tires.
My questions are as follows:
1) Based on the description above, do I need to change the back tires immediately?
2) If I change the back tires, is there a reason they wouldn't be replaced by the new tires? I don't understand why the current front tires would move to the back.
3) Do I really need to do a whole new alignment if I replace the back tires?
4) The tire store said that even though they did the alignment, Tesla has some kind of proprietary way of recalibrating that would need to be done. Is this true?
5) Inspection company said if I leave the front and back tires as-is, I should only rotate the front tires side-to-side. Tire store said they don't do that. And that it wouldn't make sense to do that.
Any help would be greatly appreciated.
