TPMS Sensors
Discussion in 'Roadster' started by jordanthompson, Oct 24, 2013.
Tags:
  1. thefortunes
    thefortunes Member
    Wisconsin
    I run (typically) 5 months out of the year with no TPMS since my winter set does not have them. As you have surmised, the only downside is the message, and ensuring that you are monitoring your tire pressures. You also can't go "left" through your VDS screens since the left arrow is now replaced with an error link.
  2. sethr
    sethr CPO Roadster #1089
    Fairfax, VA
    #22 sethr, Mar 30, 2016
    Until a week ago, I wished there was no darn TPMS. I figured I can check my tire pressure with a gauge, nothing else needed. But then I got a slow leak from a nail in my tire while I was parked for a few hours. There was only 12 psi left. Instead of potentially having a ruined tire or worse, I just went to the nearest gas station, added air, and was able to monitor the pressure as I drove to a tire repair place. So now I will pay to maintain the sensors: much cheaper than a new tire or losing control while driving.
  3. djp
    djp Roadster 2.0 VIN939
    Toronto, Canada
    Confirmed, I bought four sensors from my Tesla service centre last week. Cost was $26 CAD each, or about $20 US.
  4. dhrivnak
    dhrivnak Active Member
    NE Tennessee
    What???? I just paid $200 each for the 1.5 versions
  5. slcasner
    slcasner Member
    Sunnyvale, CA
    The 1.5 versions are more expensive than the 2.x versions. They are also more reliable.
  6. Botbldr45
    Botbldr45 Supporting Member
    Sedona, Az
    Just got my car back from Rockville SC and they charged me 17.63 each for two sensors. The antenna faulted also and cost 94.04.
  7. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
    I stopped by the Bellevue, WA Service Center today to confirm the current price of the v1.5 sensors: $223.78 ea.
    I bought a set of 4 of these several years ago for a set of winter wheels I acquired, and I'm sure I didn't pay anywhere near that price for them then.
  8. wiztecy
    wiztecy Active Member
    #28 wiztecy, Apr 7, 2016
    Here's the TPMS from my 1.5 Roadster when I had my rear tires changed. I asked them to write down the make/model/number of the TPMS, instead they took a picture of it which is helpful. Will try to hunt these down since I'm going to need 4 more for a set of 2.5 Sport forged wheel's I'm building and putting on the car.
    Here are some numbers/characters I could make out that appear to have any importance:
    BERU - Made in Germany
    FL-0105958-A
    FCC ID OYGTSSRE4TC
    2015401172
    433Mhz
    10/12/08 -22
  9. wiztecy
    #29 wiztecy, Apr 7, 2016
    No hit on the part numbers, might be a Tesla number. However I did get a hit off the FCC ID if I got that correct such as the digits. Please verify to see if I'm close. Here's the link to the Beru TPMS with the same FCC ID and its $138, so cheaper than Tesla if its the one. We can cross reference if this is correct for another manufacturer. And off of Ebay, I found the RDE010 BERU part number (same FCC ID) which came in some Porsche 911 cars, possibly others going for $50 used for all four of them (without the valve stem). I don't think I'd buy them used. However, I'm pretty sure FCC IDs are unique for each TPMS sensor model, so if true, these are the ones to get for the 1.5 Roadster (BERU RDE010):
    PORSCHE 911 TPMS SET OF 4 Tire Pressure Sensors 433 MHz RDE010
    Dill TPMS Sensor: D-9008
  10. wiztecy
  11. n2mb_racing
    n2mb_racing Member
    durham, NC
  12. wiztecy
    Correct, what I posted was for the 1.5 roadster. The 2.0 is totally different and way cheaper in cost. If you have the fcc id, you should be able to locate a compatible TPMS since the one's equipped on the roadster are encoded with a Tesla part #.
  13. n2mb_racing
    n2mb_racing Member
    durham, NC
    FYI. I called my local service center and they also said the sensors are $18 each. I'm going to go get two new ones from them.
    I guess there is no reason to look at other sources!
  14. dhrivnak
    NE Tennessee
    A further update on the 1.5 TPMS is that you do not need a special tool. They are supposed to automatically sync after a 20 mile drive. Sure enough when I picked up my Roadster they did take a 21 mile drive.
  15. DaveD
    DaveD EVs Kick Gas!
    Redmond, WA
    It might be worth contacting TPMSDirect and see if they can confirm the compatibility with the Tesla Roadster. If so, they could change their "Search By Vehicle" website feature to include the Tesla Roadster; it only has the Tesla Model S supported now.
  16. n2mb_racing
    n2mb_racing Member
    durham, NC
    FYI. I bought two of the rear TPMS sensors for the 2.0 Roadster yesterday from Tesla. They were $18 each!
    Here are photos of the sensors and of the box, in case that is helpful for anyone in the future.
    2016-04-21 08.20.44.jpg 2016-04-21 08.20.56.jpg 2016-04-21 08.21.14.jpg box.PNG
  17. glight2000
    glight2000 Member
    San Diego, CA
    My TPMS sensors are bad. I called the San Diego TSC and also received a quote of $18/each. They're not in stock, however, until later this week. I'll give an update with the installation cost.
  18. ecarfan
    ecarfan Well-Known Member
    San Mateo, CA
    $18 each?!
    I paid Tesla over $223.78 each to replace the TPMS on my 1.5 early this year, plus $49 each for a "metal valve stem". So over $1,000 for all 4 wheels.
    I'm not making that up.
  19. supersnoop
    supersnoop Tesla Roadster #334
    Pflugerville
    The 1.5's are much better and much more expensive. The 2.x TPMS is one of the major weak points of the model, but the replacement sensors are, as you can see, much, much cheaper.
  20. hcsharp
    hcsharp Active Member
    Vermont
    In over 5 years I've never had any trouble with my 2.5 sensors.
