Ok so the Roadster all and all isn't that bad on the track. With the weight there is ALOT of body roll. Almost like it could use a thicker sway bar. Also, the understeer I mentioned got worse as I pushed the car. Come to find out the car is SUPER adjustable.
Also owners will be please to see that the car can handle its own on the track (but just for about 15mins). I drove today all in std mode and it didn't seem to prevent the motor from overheating vs running it in performance.
Everyone was coming up to me and asking questions and a couple people said it was the highlight of the event. One guy said it was funny to see my car go so fast, set up for a pass, and then not hear anything as I zipped around!
- - - Updated - - -
So the rear swaybar was set in the middle position. We move it to full stiff. That seemed to help the understeer a bit but I think it could use a bit more. The rear is so heavy it's hard to rotate but have to be careful once it does.
But, the best thing was that we found out that the coilovers are easily adjustable. The mechanic said that they are ride height adjustable...also on the coilovers, they have 10 clicks of adjustment.
He stated that sometimes with these that look like they adjust both compression and rebound, you might turn them and barely notice anything or on the other extreme totally unsettle the car!
So we decided to go 2 clicks firmer on both the front and rear. What was cool is that you can turn these without having to unload weight from the car. There is also a mark and EASILY seen numbers!
After adjusting two clicks and firming up the rear swaybar I was heating the rear tires much much better! The car also felt more neutral, but could have used a bit more. The car got a bit squirrelly during the session but I noticed that my temps got the PSI back up to 30 front and 40 rear! WAY to much. I think if I would have stayed the last two sessions I could have gotten it dialed in more.
Anyways, here is a pic on how little they raised the car to adjust things...and the rebound/compression adjustment knob
*thanks to PST for the quick work!
- - - Updated - - -
