This has been discussed in this thread. And while it is a somewhat reasonable work-around, there are still several issues with it. First, I assume that you mean setting the "speed warning" because there is no way to set "the cruise" in advance. The speed warning controls the cruise control speed for no reason whatsoever.I haven't tried this yet, but wouldn't setting the Cruise to "Absolute" and then down to "20" effectively do what you-all have been asking? Since you probably won't be engaging cruise when you're going under 20MPH, then the system will choose the current speed of the vehicle?
There are many (apparently... they've chimed in here) people who turn on TACC when they are stopped, or in stop-and go traffic for the express reason that when traffic clears up, the car will accelerate back to the speed limit or the set speed. This work around defeats that "feature."
Next is that this means that the speed warning cannot be used as an effective.... speed warning. So why have a speed warning?
And finally.. this is still random and clunky. Cruise control and speed warning should not be connected. And cruise control should never immediately accelerate when set. If nothing else there needs to be a check box to force TACC to initially set at the current speed no matter what the speed warning says.
