23′-5″ (7.14m) x 5′-3″ (1.60m) - Weird that they make them just a little too big for a 20' intermodal container (interior dimensions - 19′ 3″ (5.867m) x 7′ 8 19⁄32″ (2.352m) x 7′ 9 57⁄64″ (2.385m) ); they'll have to use 40' intermodal containers. They might be weight-limited rather than space-limited, but that just makes it worse - 40' containers hold 26,2 tonnes vs. 20' containers which hold 28,2 tonnes.
That said, I don't think they're weight-limited, given the 2673 kWh capacity (26,2 tonnes would work out to 101,75 Wh/kg). Which just makes the decision to make it just a meter too long to fit into a 20' container (with excess room above and to the sides) all the more baffling to me.
If I had to guess, the plan is that they use 40' intermodal containers and include a bunch of support hardware in the container with the megapacks. But that's just a guess.
They weren't hacked, they are fake (bot) accounts for hire for anyone wanting to have voices spouting their propaganda.I thought it was odd there were a number of twitter accounts with barely any activity over the past few years which suddenly came alive with new voices that sounded like TSLA short-sellers.
Everything you say is true but I think it is more simple: Model 3 is not yet on the administration´s eligibility list for the 2000+2000 EUR incentive. Don´t know why it is not there, but don´t think because Tesla doesn´t want it there. Likely updated next Tuesday...
This page saysThey might be weight-limited rather than space-limited, but that just makes it worse - 40' containers hold 26,2 tonnes vs. 20' containers which hold 28,2 tonnes.
The maximum cargo weight that can be safely and legally loaded, when a triaxle chassis is used, for most US areas is:
- In a 20” container - 44,000 lbs (19,958kg)
- In a 40” container - 44,500 lbs (20,185kg).
I wonder if a Megapack could be modified into a semi-trailer for the Tesla semi. I like the idea of a mobile Tesla battery transporting sunlight across the country.
Happy weekend everyone.
Are these megapack batteries coming from GF1?
Do they have the capacity to produce that much?
I'd be surprised if megapacks were anywhere near 134 Wh/kg; that sounds awfully low, even for a stationary product.
A few observations-
It’s not weird IF Tesla were considering only the NoAm market, as it is at least as easy and efficient to place any number of them on 53’ flatbed trucks (2 w/o any permitting; 4 if they go to Wide Load permitting).
For projects across the world then I absolutely agree with you.
However, I have to disagree about your descriptor: it’s fully 22% longer than a fit. So why can’t they make it just enough wider and taller...and shorter? Perhaps there are site-specific reasons for this project (doubtful); perhaps this is the ideal configuration and for international projects they will have to compromise for shipping reasons (and if so, certainly hope they scrunch the shape so that TWO can fit in a 40).
Initially the S was around 160Wh/kg at the pack level as I remember, (not sure where they are now). I would think lower density NMC for storage plus all the ancillary components could easily be heavier than 134Wh/kg.
Your reasoning is circularFeel free to think it. But learn some basic social interaction skills. Believe it or not, "I'm so much smarter than you" isn't exactly a powerful persuasive stance. Indeed, claiming that immediately makes people think that you're not, given that you clearly lack the common sense not to write such a thing.
Or worse: they messed up
