there's few games but definitely cannot remember the names. but there is no Sonic.@yessuz @dadthesaint which games are available with your cars? Do you have Sonic etc. installed or are they missing?
have a play with this - I found it helpful - Tesla VIN decoder.finally found my VIN LRWYHCEK5NC23xxxx so what does this mean / tell me then ?
i did not even checked my battery
likewise..finally found my VIN LRWYHCEK5NC23xxxx so what does this mean / tell me then ?
letter N - 2022 model.likewise..
LRW3F7FS2NC4 - I am also now totally confused about which is the most up to date motor and battery, which is best etc.
Does this look like the latest model?
Well, I kinda disagree, Tesla even stated that you can still use the sentry port for a controller, which you could of course, so there is actually no good enough reason for me why they would block the games. You can also use a non-powered usb-hub to use sentry and a data-stick simultaniously which in my opinion is just a compromise. But this is becoming a neverending story and it's quite annoying. We will see what's gonna happen in the future.Sonic and any Data required Apps will not be installed by vehicle's "smart" firmware because vehicle recognises that the Data-enabled USB Hub is not present and Tesla has downgraded the Specification of all cars manufactured from 15 Nov forward as having the Charge-only port, there are no exceptions or shades of grey
Ryzen and 12V Battery? Is that correct? Always thought it's supposed to be a 15V or 16V battery now... confused^^
battery 12V but Li-ionRyzen and 12V Battery? Is that correct? Always thought it's supposed to be a 15V or 16V battery now... confused^^
does this mean they come with the Ryzen chips fitted ?letter N - 2022 model.
You haveSorry have I missed something, why are the games not available in 2022 cars?
reps said few times already (to me and others) that all 2022 models will come with ryzen fitted. we have very limited pool of verified information (myself and very few others) and all seems to get Ryzendoes this mean they come with the Ryzen chips fitted ?
But I am still curious to find out, if the games are truly not available in the new cars.
No idea what your post is supposed to convey^^ Sure, you can do pretty much anything. But as I said, this is what Tesla told me to be able to use sentry, to play games and to listen to music. But if that is the solution they offer at the moment then I don't understand why the games keep being blocked. Can you?Sure can, you can even connect a long USB port while parked in your garage to your home and access from there. There is no one policing you from using any of the USB ports of your vehicle or anything with respect to your vehicle
Games are included, only Games requiring a Data-enabled USB port are no longer included because due to global constraints on supply Tesla have deleted and no longer supplies a Data-enabled USB port in the centre console and have replaced it with a charge-only USB port hence their firmware detects that all vehicles manufactured after 15 Nov 2021 no longer have a Data-enabled port hence remove the relating games from being downloaded. You can always call Tesla Parts and purchase the newer Data-enabled Port and install it your self but will ned a Tesla technician to connect their laptop to reconfigure the vehicle's internal systems management system to recognise that the hardware has physically changed and a Data-enabled USB Hub has been installedSorry have I missed something, why are the games not available in 2022 cars?
Is this true? We tried that many times in Germany, they told us they are not allowed to sell those parts to the cars that didn't come with the data ports already fitted. You can obtain an offer, but as soon as you try to purchase it, they cancel the order. Also it wouldnt make any sense otherwise. If they have the parts, they could just put them in the cars. Tesla stated that less than 1% uses the data ports which is why they were scrubbed.You can always call Tesla Parts and purchase the newer Data-enabled Port and install it your self but will ned a Tesla technician to connect their laptop to reconfigure the vehicle's internal systems management system to recognise that the hardware has physically changed and a Data-enabled USB Hub has been installed
