Ok - let's stop guessing around and measure out those adapters.
We have four possible connection points iside the california twist lock connector: red ring, black ring, green ring, white ring (see pics...).
I have two of them: one 10A and one 32A adapter. (I have a SWISS Version of the UMC, so default is 10A).
The 10A adapter:
It is build according to M.E.'s 15A schematic (
http://www.teslamotorsclub.com/attachment.php?attachmentid=2481&d=1314961464). Look at the following image:
Only phase (red ring, brown cable), neutral (black ring, blue cable) and ground (green ring, yellow-green cable) are connected. The third pin (white ring) is empty. The purple pilot cable is missing too.
I guess the umc defaults to 10A if the purple pilot cable is left open.
The 32A adapter:
Phase and neutral (black and red cable) are on red ring / black ring and ground is on green ring with a green-white cable. We have the purple pilot cable shorted together with the ground wire on the white ring. This adapter is not built according to M.E.'s RFMC specs.
Furthermore the purple wire is left open on the CEE32-Connector side. So it's just a shortage between ground and white ring.
The 32A is the "biggest" adapter for the SWISS UMC. If we look at the images from W.Petefish (
http://www.teslamotorsclub.com/attachment.php?attachmentid=2478&d=1314941461) we can see that his 50A adapter (which is the "biggest" adaptor for US UMC's) has the same wiring: purple is shorted together with ground.
So those two cases are very clear now: the "smallest" adapter has an open purple pilot wire while the biggest adapter has the purple pilot wire shorted together with the ground wire.
I don't have other adapters at hand. Could anyone else measure out the remaining adapters(30A for US UMC's)?
