It's here:The full report, which should include their methodolgy, is supposed to be out today I think.
Global Warming Emissions and Fuel-Cost Savings of Electric Cars (2012) | Union of Concerned Scientists
Full report at the bottom of the page.
It's here:
Haven't found the calculation, yet, but see page 8 of the full report where they say that they do. The Technical Appendix goes into great detail on how they calculated it for electric vehicles.There was no attempt whatsoever that I can see, with a quick perusal, to address well-to-wheels for ICE cars.
I think it's reasonable to use currently available vehicles that most people might actually buy. The Roadster doesn't really count.Why do the critics always use the Leaf or Volt as examples. The Leaf they say takes 0.34 kwh/mile. Today onthe highway in my Roadster 2.5 Sport I used 0.24 kwh/mile. In Connecticut they said the Leaf gets equivalent of 67 mpg, but if you use the actual numbers i get on my roadster it is more like the equivalent of a 95 mpg car.
I went through the Prepublication paper as well and though found references to well to wheel, I couldn't see anywhere were the cost was calculated for an ICE vehicle. It calculated the cost of EV to a miles per gallon of green house gas equivelant. No reference to what one gallon of ghg is equal to or what assumptions upstream it makes on the production of a gallon of gasoline.There was no attempt whatsoever that I can see, with a quick perusal, to address well-to-wheels for ICE cars.
Edit: They use 11,200 grams CO2 / gallon of gasoline which they took from GREET. The actual burning of a gallon of gas will result in 8,170 grams CO2.
This means that the work is unverifiable.
Does anyone have any actual wall-to-wheels efficiency for their Roadster?Unless most EV's are going to be small sports cars their efficiency is probably not going to be similar to the Roadster. There is also the issue of charging efficiency, the Roadster seems to use a lot more energy managing the pack than other EV's, which lowers it's actual wall to wheels efficiency.
Not without mentioning the capabilities of the Roadster and how that it is entirely reasonable to assume that all EVs will get better with each year and the Roadster is proof.
Amount of Electricity Used for EV Charging
Consumption
For the sake of simplicity, we assume every EV owner drives his or her EV the same number of miles each day. In this analysis we use 30 miles of daily driving for each EV, based on the average daily mileage per vehicle determined by the 2009 National Household Transportation Survey. We also assume each mile driven in an EV requires 0.34 kWh of electricity from the outlet, based on the 0.34 kWh/mile plug-to-wheel efficiency of the first-generation Nissan LEAF, which is the most prevalent plug-in EV on the road today. Other such EVs have slightly different electric-drive efficiencies and therefore may require more or less electricity to operate, but the efficiencies of the Tesla Roadster and Chevy Volt, two other well-known EVs, are very similar to that of the LEAF. Thus our analysis assumes that 10.2 kWh (30 miles x 0.34 kWh/mile) of electricity are used to charge every EV each day of the year. We ssume all EV charging is done at home, where the majority of EV charging is likely to occur. Any charging done at the workplace or other locations would lower household energy consumption.
The EPA's published testing procedure for EVs it's nothing like driving at a steady 55 mph and further more, the actual test results are reduce by a somewhat arbitrary 30% to make it more like "real world". Never mind that Tesla's published values for 55 mph driving don't include charging losses which are at least 10-15%.If we consult Tesla's published values for the Roadster at 55 mph its efficiency is 0.23 kWh/mile or 32% more efficient than the number used for the LEAF. I wouldn't say that a 32% increase in efficiency is "similar". :wink:
My real world tests of the LEAF show it around 250 Wh/mi (from the wall) at a constant 55 mph on level ground. Or basically the same as the Roadster once you take into account charging losses.
Tomsax has access to both a LEAF and a Roadster and I believe has performed tests of similar nature?
(runs off to google)
Oh yes, he has: EV Efficiency: Tesla Roadster and Nissan LEAF Compared - Tom Saxton's Blog
His numbers show the Roadster about 5% more efficient at 70 mph. Not unexpected, The Roadster probably has a smaller CdA than the LEAF given it's about half as tall. Results would probably be similar at 55 mph where aero drag is a lower proportion of total drag.
Tom's test does appear to relying on on-board instrumentation from both cars which is also a source of error and makes the assumption that charging losses are similar - ideally one would charge both cars to "full", perform the exact same drive, then measure how much energy it takes to re-charge each car back to full.
EVs charged entirely from renewable sources like wind and solar power produce virtually no global warming emissions.
For me personally? It seems to penalize EV range too much. But for the average person? Hard to say. (BTW - the 30% adjustment factor is also applied to gas cars).In your opinion does this "somewhat arbitrary 30%" reduction in EV test results actually produce more accurate results, or does it render comparisons with ICE vehicles less fair?
