here are some pictures of the UP lowering bracket
pictures of the car are on standard setting which is 28 Inches from ground to fender
low setting will measure to 27.5 inchesView attachment 427425
Rather than fixed brackets, go for lowering links that adjust, or if you're like me, 3D print lower links that are exactly as long as what you'd like for a drop. I chose +6mm longer links at all corners which produces very similar to the car picture posted above. I think +7mm would be bang-on match to what is pictured.
It' not a load bearing part. If you take the wheels off you can see where the links attach to a rather flimsy piece of metal.I don't know how tesla suspension is set up but how can you 3d print a bracket that will actually handle the forces and weight of a heavy vehicle? I'm interested to know and think this would be a better route to go if it's more customizable and cost effective.
isracing - we've had sets of our brackets on ravens for a 3-4 months now and everything is working perfectly.
