I'm an engineer too, which lots of expertise in electronics and software, so I know enough to recognize stupid software when I see stupid software.
Tesla designs their software with the assumption that you always have connectivity and if Tesla denies you power you have an alternative. I live in the mountains where it gets cold and I had my 12 volt battery decide to throw the low voltage error when I was in the middle of nowhere and my cell phone battery was super low. I normally charge my cell phone when I'm driving, so when this happened to me, and the Tesla decides to disable the USB chargers in the car (which is pure stupidity again, because there's no way the current being drained by the USB charger could possibly impact anything. ) So when a car can do this to you when you're hours away from any kind of help it's kind of a jarring experience that I will try to make sure doesn't happen again.
All my other cars, one of which is 20 years old I was able to install lithium batteries with zero issues. To avoid this potential bad situation again, I decided to upgrade to lithium so I don't have to replace completely obsolete 75 year old battery technology every two years. Of all the companies in the world that should be able to handle a Lithium battery I would suspect Tesla would be the one to handle it the best.
SURPRISINGLY NOT YET. But I know this is just a software update to fix, and software updates are something Tesla is excellent at. The technology exists to very inexpensive not have to run into this issue for 10 years. Explain to me why Tesla should address this issue?
Because it's a niche application and you are the first one actually to report a result as bad as your's (even the Ohmmu battery that had lots of problem with errors didn't do as bad as your's)? Did you try to plug in a regular 12V to confirm what it usually draws to make sure there is no other vampire load or it's not trying to do a load test? 20A sounds a lot like about how much the car computer draws, so perhaps it is running the full computer momentarily on 12V battery, although generally it should run it on the PCS.I'm an engineer too, which lots of expertise in electronics and software, so I know enough to recognize stupid software when I see stupid software.
This is not correct. The coils of the contactors are the only parts connected to the low-voltage battery - these only consume a few watts. Much higher current (hundreds of amps during acceleration, regenerative braking, and DC fast charging) flows through the contacts of the contactors.The main high current draw the 12V battery needs to power are the contactors.
Non-heat pump heaters run off HV, not 12V. At least that was the case with the S and X and I can't see any reason to change it. Plus 6kW at 12V would be a 500A load which would far outweigh the capacity of the DC-DC converter.This is not correct. The coils of the contactors are the only parts connected to the low-voltage battery - these only consume a few watts. Much higher current (hundreds of amps during acceleration, regenerative braking, and DC fast charging) flows through the contacts of the contactors.
The highest loads on the low-voltage system are the electric power steering system and cabin heater (on models without a heat pump).
If you live in a cold climate, two years is about what you get out of a lead acid battery (roughly speaking).Two years? Is that anecdotal?
Yes, great idea to plug in a 12 volt battery!! See my lengthy post about what happens in this case. Quick summary: absolutely nothing close to what it does with a lithium battery. BTW, the lithium battery I bought cost $120 and if the specs are correct, I should never have to replace a 12volt battery again - which is a pain in the ass and potentially dangerous situation if you are unlucky like I was and have this happen when you're out in the middle of mountains with no power and no cell coverage!!Because it's a niche application and you are the first one actually to report a result as bad as your's (even the Ohmmu battery that had lots of problem with errors didn't do as bad as your's)? Did you try to plug in a regular 12V to confirm what it usually draws to make sure there is no other vampire load or it's not trying to do a load test? 20A sounds a lot like about how much the car computer draws, so perhaps it is running the full computer momentarily on 12V battery, although generally it should run it on the PCS.
The main high current draw the 12V battery needs to power are the contactors. One draws a peak of about 100A, two would be 200A. This is a piece of cake for lead acid batteries, but some LiFePO4 would struggle. That may be why Tesla chose a higher voltage lithium ion solution (not LFP) instead for their own lithium low voltage battery.
With the new updates and warning system, most people seem to be getting about 4 years of life out of it. At $85 a pop for the lead acid, lithium might not make a lot of sense for people unless it's very inexpensive.
Tesla absolutely has zero incentive to change their BMS to play with lithium batteries. They are going to optimize it to squeeze as much life out of lead acid, while trying to give an early warning for failures (and keep the car awake in those circumstances). It's up to the people designing the lithium replacement batteries to design their BMS to play nice with Tesla's system (basically fool it into believing it's a lead acid).
In observing what happens with a 12 volt lead acid battery in a Tesla while it is powered on, I could NEVER see it actually using any power from the 12 volt battery. The only thing it does is try to charge it at a gentle 3 amps. What happens with a LITHIUM 12 volt battery is willful destruction - 20 amp continuous draw EVEN WHEN PLUGGED INTO A CHARGER until it gets down to 12.5 volts, at which point the error message is generated and the car refuses that charge the 12v battery - even though it is a brand new battery and chargers completely fine with a legacy 12 volt car charger.This is not correct. The coils of the contactors are the only parts connected to the low-voltage battery - these only consume a few watts. Much higher current (hundreds of amps during acceleration, regenerative braking, and DC fast charging) flows through the contacts of the contactors.
No, I'm talking only about the peak momentary coil switching current. The peak current actually going through the connection is way more than 100A (it's more like 1000A).This is not correct. The coils of the contactors are the only parts connected to the low-voltage battery - these only consume a few watts. Much higher current (hundreds of amps during acceleration, regenerative braking, and DC fast charging) flows through the contacts of the contactors.
Both of those loads are powered by the PCS (while HV is connected) and not the 12V battery (as others pointed out, cabin PTC heater doesn't run on 12V, but rather high voltage). They also are not on while the car is asleep, so would not contribute to drawing down the 12V battery, while instead the contactors obviously need to be run off the 12V battery when car is asleep (and HV is not connected yet).The highest loads on the low-voltage system are the electric power steering system and cabin heater (on models without a heat pump).
That $120 price makes me suspect the issue is the BMS in that lithium battery or there is something iffy about it.Yes, great idea to plug in a 12 volt battery!! See my lengthy post about what happens in this case. Quick summary: absolutely nothing close to what it does with a lithium battery. BTW, the lithium battery I bought cost $120 and if the specs are correct, I should never have to replace a 12volt battery again - which is a pain in the ass and potentially dangerous situation if you are unlucky like I was and have this happen when you're out in the middle of mountains with no power and no cell coverage!!
the vast majority of people don't want to bother with this and prefer to pay Tesla $250 dollars to come replace the battery for them.
From what I've uncovered the last few days, if the Ohmmu is a lithium ion battery, it would have the same issue as the one I have. The only way to avoid this problem would be if you had some fairly complex electronics that have to be able to maintain 14.6 volts being drawn at 17 amps for a couple seconds. I think a pretty hefty capacitor might be able to do the trick, but I really have no idea because I've never touched an Ohmmu.That $120 price makes me suspect the issue is the BMS in that lithium battery or there is something iffy about it.
The Ohmmu battery that most people have used (and still got problems) instead is $480.
12V Lithium Battery for TESLA Model 3
From the other threads, even the problematic ones can last a week or two before popping an error, not pop the error almost immediately in hours like yours did.
Looking more closely at your original post, you report the 20A draw after it pops the error. Actually when a Tesla pops the error, it never goes to sleep again, so the HV is always connected. That means it should be drawing from the PCS now. It also should stop using or charging the 12V given it has determined it's a failed battery. This mode was added after people have gotten stranded and this have helped many people be able to have a failed battery and still use the car while they get it replaced.
Where are you seeing this "20A" number? Are you certainly it doesn't include draw from the PCS? 20A is on the order of how much the car should be drawing while it's awake to keep the computers on.
I think California prices are higher than what you are showing. But in any case thats's still $129 million dollars a year revenue for Tesla.
Just copied from evseekers.com:I think California prices are higher than what you are showing. But in any case thats's still $129 million dollars a year revenue for Tesla.
You say it's a lithium detection routine, but it's more likely just the standard failing lead acid detection routine. This routine used to not exist and there were people stranded. So Tesla added a routine to detect a lead acid battery that is failing and this is the result. There aren't very good ways to detect lead acid that is on the way out, other than a load test, and this may be what it is after it detects the battery is behaving in an unexpected way (which a lithium battery is prone to do). Basically what Tesla is trying to avoid is the battery suddenly dying without warning and the car won't have time to keep the car awake.From what I've uncovered the last few days, if the Ohmmu is a lithium ion battery, it would have the same issue as the one I have. The only way to avoid this problem would be if you had some fairly complex electronics that have to be able to maintain 14.6 volts being drawn at 17 amps for a couple seconds. I think a pretty hefty capacitor might be able to do the trick, but I really have no idea because I've never touched an Ohmmu.
If that's what I said, about the 20A draw only happening AFTER it pops the error, that was written incorrectly. The 20A draw starts happening right fairly soon after the routine to determine it's lithium runs. The first time this happened I was driving so I could not monitor what and when it happened. The second time I tried it my car was sitting in my garage while plugged in and I could see the 20A draw in a fairly short amount of time way before the error message shows up. The error message only shows up a fair amount of time after the 20A draw down has dragged the voltage down far enough.
Yes, once the error happens the car will never sleep, nor will it charge the battery up above 12.6 volts again. NOTE: if you reboot the process with a lithium battery you that is new of you have manually charged to at least 12.8 volts, the Tesla will charge that lithium battery all the way up to 14.6 volts. But it only does this once, because once it's at 14.6 volts and runs the "battery type detection routine" it will only drain the voltage to below 12.6 volts and never charge it again. To me this is proof of deliberate sabotage. If it could charge it up once, why couldn't it charge it up again? Also, what happens with a lead acid bears NO resemblance to what the Tesla does to a Lithium battery.
$85 seems to be the price everywhere including in California. Most of them are replaced under warranty, so Tesla isn't getting real profit from it (it doesn't cost Tesla $0 for the battery or labor). $85 is a very good price for a sealed battery of this size. I think people have looked and there aren't any third party ones that come close.I think California prices are higher than what you are showing. But in any case thats's still $129 million dollars a year revenue for Tesla.
