Again, I own both vehicles. The P85 is most *definitely* traction limited at the low end. No question about it. When I stomp it in the P85 from a stop the tires struggle to maintain traction at times, vs the P85D where they might struggle for a split second before it properly lays down the right amount or torque. If I turn off traction control on the P85 you can barely keep it on the road under 30 MPH because the tires will spin and spin.
I think you're either confusing the facts or trying to confuse others. You're not going to confuse me, however.
The P85D, with twice the traction available can technically, if it were actually able, lay down roughly twice as much torque as the P85 could at the same point in the 0-60 curve (it's roughly twice because during a launch the front wheels have slightly less traction than the rear wheels do the weight shift). But it can't exceed that sum regardless of if the motors are rated for 50 billion ftlb of torque, regardless of if the power is available or not (which we know it's not). So yes, the peak combined torque of output the P85D can be higher than the P85's peak toque, but that doesn't mean it can utilize it while traction limited (< ~30 MPH).
The P85D can lay down more power to the ground quicker because of the added traction of AWD. I mean, this isn't even me saying this. The CEO of Tesla Motors has specified exactly when the cars are traction limited in conversations previously. My findings concur with those comments within a reasonable margin.
So again, if they P85D were given 1000 HP "motor power" front and rear motors capable of 1000 ftlb of peak torque each... it's not going to make a difference if the tires spin, and definitely not going to make a difference if beyond the traction limited phase of the curve the car can't continue to ramp power to reach high torque at higher RPMs.
