Upgraded Interior lighting M3... Toughts?
Discussion in 'Model 3' started by djgabriel2004, Feb 11, 2019.
  1. djgabriel2004
    djgabriel2004 Member
    Boca raton, FL
    I did some upgrades in my Model 3 Ambient Lights. They are controlled from the Main Screen.
    Ambient light Upgrade M3
    What do you think?
  2. Big City
    Big City Member
    Middleton, WI
    I think you should post those pictures in this forum.
  3. djgabriel2004
    Boca raton, FL
    yes you're right
    Here some pictures attached.
  4. Eth3r
    Eth3r Member
    How do you control it from the screen?
  5. Lifeinabox
    Lifeinabox Member
    Los Angeles
    So more details, please...
  6. Dre78
    Dre78 Member
    Chicago, IL
    Nice! Tap into existing power source at feet? What LED strip did you use? Multiple colors?
  7. chronopc
    chronopc Active Member
  8. djgabriel2004
    Boca raton, FL
    I’ll be posting installation pics and the materials I Used for this mod maybe tonight or tomorrow. I’m at work
  9. djgabriel2004
    Boca raton, FL
    Hi All,
    Here is a little DIY for the Ambient Lights.
    Estimated Cost $150, Estimated Labor time ~3hs
    IMPORTANT IMPORTANT IMPORTANT: don't do that if you don't have basic electric knowledge or if you don't feel confident with that mod. Also Tesla Might void your car warranty if you do it.. soooo do it on your own risk.
    At the beginning I tried with EL wire but The model 3 Doesn't have any place to put it and I didn't like how it looks during the day so I found this kind of optic fiber with a Laser light that fits perfectly in the M3 A/C Vents.
    There's a Small Gap at the end of the Air vent where you can pass the fiber thru and it will hold it. don't pull to hard because the Fiber can break.
    you need to remove the Plastic triangle, pass the fiber thru the holes and grab it in the foot well (Remove the plastic where the foot well light is (1 screw and 2 little plastic things that you need to pull out)
    Since Tesla has the Self healing fuses where it will cut the power if it detects more power draw than what it is expecting I had to find another Ambient light where I can attach it. so the next one is the Ambient light that is in the door right where the cup holder is.
    - You need to remove the door panel (there's a 3rd Screw under the Plastic red light) check the here the video.
    it will look something like this.
    The best way to pass the wire thru the rubber booth is from the door to the car so you might need to remove the speaker. there's some youtube videos with good ideas... I used a Bike brake wire plus a zip tie.
    The wire needs to be attached to the light bulb wire, RED-RED and BLACK-BLACK also follow the original harness, put tape every 5 inches or so to avoid any lose Vibration remember (vibration=noise)
    You can see how I ran the wires in this video
    There's space where you can put the Laser and the voltage to USB converter under this plastic
    Hope you liked that mod. Let me know if you have any questions.
    Materials needed
    -2.5M Optic Fiber plus Illuminator (Link)
    -12v To USB Converter (Link)
    -24 AWG wire (Link)
    -Low Voltage connector (Link)
    • Informative x 3
    • Helpful x 2
  10. djgabriel2004
    Boca raton, FL
    #10 djgabriel2004, Feb 11, 2019
    A Day time video.
    Night time
  11. djgabriel2004
    Boca raton, FL
  12. chronopc
    I like it, but I am not willing to try that.
  13. DdotRoq
    DdotRoq Member
    Miami, FL
    Beautiful upgrade. Your photo with a bunch of tools gave me anxiety, so while I believe it is beautiful, I don't have the courage to try this myself.
  14. Trips
    Trips "Boring bonehead questions are not cool. Next?"
    Omaha, NE
    Love it. What did you do with the footwell lights? I saw something similar with the door and this seems a lot cooler.
  15. Lifeinabox
    Lifeinabox Member
    Los Angeles
    Same.
  16. djgabriel2004
    Boca raton, FL
    Footwell lights are from Abstract ocean.
    I was playing with the doors too and it look like this but I didn't install it yet bc I always test it a few Nights (and days) before to see if really like it.
  17. DdotRoq
    DdotRoq Member
    Miami, FL
    What floor mats are you using?
  18. djgabriel2004
    Boca raton, FL
    look them in ebay: HEXOMAT - All-Weather Heavy Duty Floor Mats
