Hi All,
I have a set of the OEM 19” Sport wheels from my old Model 3 LR that I want to use on my current 2022 Model 3 Performance. These wheels are from the 2017-2020 generation of Model 3’s so it doesn’t have the 3mm lip to accommodate the stepped hub on the Performance.
The part number for the wheel is: 1234224-00-A
How can I safely use them on my Performance 3? I was trying to do some research on this and it seems that it should be possible using a 5mm spacer?
Can anyone confirm if this is true and if so what brand/spacer/spec is best to go with? From what I understood, there is about 5mm of unthreaded length on the wheel studs of the Performance 3’s so this should really not negatively impact anything while providing a flush mounting surface for the 19” wheels.
Thanks in advance for any replies.
![1659967018778.jpeg 1659967018778.jpeg](https://teslamotorsclub.com/tmc/data/attachments/824/824298-c4c34b146e25d796dbe8c1f18b48dd6d.jpg)
