I have a Clipper Creek EVSE I use to charge our Volt and now new MY. I'm confused on how to properly use it. Page 152 in the Owners Manual says:
Tesla offers adapters (for example, J1772 and CHAdeMO) to allow you to plug into the most commonly used public charging stations in your region. Open the charge port door using the touchscreen (see Charging Instructions on page 154), plug the adapter into the charging port on Model Y, and then connect the station's charging connector to the adapter. There is no removal instructions.
OK that's easy, I insert the adapter into the car and plug the J1772 end of my CC into it. That's easy, charge ramped up to 40 amps and was happily charging at 35 mph. But what's the correct method to UNPLUG this assembly.
I pressed the UNLOCK button on the display screen, I could hear a click but when I tried removing it as one assembly it wouldn't come out. So I pressed the release tab and pulled the J1772 plug out leaving the adapter in the car and tried pulling that out it was locked again, so I pressed the unlock button on the phone and I heard the click and I really had to TUG to get it to release. I thought I was going to pull the charge port out of the car. It finally came out.
But the question is, what's the correct method to unplug the adapter and EVSE J1772 from the car?
Thanks in advance
Thanks in advance
