I also can no longer connect, tried 3 different iOS devices.
@Turbo3 - what has Tesla changed? Looks like I'll be needing to update some message ids and decodes for my setup. Still enjoying 7.1 here.
Hi, @Turbo3 , how can I help providing ELM Trace? I found an option called Trace ELM, but can I just run the app with the option on and wait for a few minutes then send the log (where?) to you?New Android test version 0.1.29 has just been upload. It should fix the bug where TM-Spy would sometimes crash when first started after being installed.
There are instructions at the bottom of the built-in Application help file. After enabling an ELM trace you need to exit TM-Spy (full exit, not just switch away) then restart TM-Spy at which point you should see the word "Logging" bottom center. Let it run a few minutes while connected and then send me the TRC_xxx.txt file. Full instructions in Help file.Hi, @Turbo3 , how can I help providing ELM Trace? I found an option called Trace ELM, but can I just run the app with the option on and wait for a few minutes then send the log (where?) to you?
Thanks. Will do today. So I understand that it is like a diagnostic mode to create a log file.There are instructions at the bottom of the built-in Application help file. After enabling an ELM trace you need to exit TM-Spy (full exit, not just switch away) then restart TM-Spy at which point you should see the word "Logging" bottom center. Let it run a few minutes while connected and then send me the TRC_xxx.txt file. Full instructions in Help file.
Got the same issue with iOS
Thanks for the update.Everything is working fine after the latest update (0.1.35)
View attachment 173946 FINALLY got a batch of these newer Sept 2015+ connectors and terminals in.
Panjo link: Tesla Model S/X OBD2/CAN adapter cable (Sept 2015 +)
