AlanSubie4Life
Efficiency Obsessed Member
Have you ever tried walking up to the door with your phone in your back pocket? Did you notice the door did not unlock?
I think this is the issue you are seeing. To unlock/wake the car you have to be very close to the door with the phone very close to the door. At the charging port you are nowhere near a door.
This is not the problem. You can do the "trick" of tapping a rear door handle without changing position, and it then allows the charge handle unlock.
I am fairly sure that your car has the same behavior. Try removing the charge handle sometime without waking up your car (make sure it is sleeping first - using the widget, not the app, of course!). It won't release it. Obviously if the car is charging it is not sleeping. So in that case it will ALWAYS unlock.
