*sigh*
So you don't believe two copper contacts in a high amperage connector can never get into a case where they can melt and cause issues. Ok fair enough you win, I'll will ignore the my melted copper EV Anderson connector that I thew away from a current overload (I shorted one out with some ultracaps through it). btw there have been more than one EV DYI builds with connectors that have stayed withing it's rated power limits but due to resistance issues have melted (and it was after inital pre ramp).
An ultracap? Really? You're trying to compare a 40A/240V outlet protected with a 50A OCPD upstream, and at least one additional larger OCPD upstream, with the instantaneous unchecked power output of a charged ultracap? Talk about being out in left field...
(Keep in mind I've already established that the reliability of the upstream OCPDs is not Tesla's problem, nor can their reliability be detected by voltage drop...)
You need currents in the order of kiloamps to do this type of damage...
As for the DIY EV builds, you're talking a whole different set of issues there that could have taken place, likely have little, if anything, to do with this particular issue with Tesla... and a failure analysis which will be left for another forum on DIY EVs. For the record, I've heard zero reports of a Tesla charge port inlet going up in flames...
Math to the rescue again... it would take ~500A for 10+ seconds to electrically melt the wiring in the UMC cable. It would take ~1500A for 10+ seconds to do the same to the wiring inside the car. Instant weld amperage for either is well over 15kA... well beyond what any OCPD would trip at, let alone that the supply wiring couldn't even provide that kind of current most likely. For fun, within reach of a decent ultra cap, though... and probably also possible from the DC side of the Model S battery.
I guess I have to get specific. Say it wasn't the the ground wire that has the insulation fault, but the other two wires start that start to arc. you hope in a short amount of time that the ground wire insulation will melt due to the arc heat and trigger the GFCI but that might take a second(s). So if you were the car for safety reasons do you just keep chugging along charging, or ramp down? I personally would at least have the car ramp it down.
What you describe is called an arc fault, and is prevented with an AFCI, as mentioned above. It has absolutely nothing to do with voltage sag. The AFCI monitors instantaneous current usage at a millisecond level and compares the patterns to lab produced arc faults, defines a probability that a similar condition is happening or not, and acts or doesn't act almost immediately. For what it's worth, as far as I know the Model S does NOT have any type of AFCI. The UMC and HPWC do have GFCIs however.
The lack of an AFCI doesn't justify the voltage drop reaction anyway. In the event of an arc fault, lowing the current isn't going to stop the arc. In fact, in this case lowering the amperage will increase the voltage and likely intensify the arc since an arc's ability to jump an air gap is directly proportional to voltage. Decrease amperage, which in turn increases line voltage, increase arcing
I can make up more plausible scenarios, but I hope you see that having a safety circuit always monitoring for voltage sag makes for a safer design.
You can make up thousands of scenarios. Until you find me a code reference in the NEC (or proposed addition, or similar safety code) that shows a safety method/device/procedure/etc for accurately detecting an actual real world fault condition based entirely by monitoring voltage sag, or some other actually plausible reason to cause false faults and inconvenience the majority of the time it triggers instead of actually preventing an unsafe condition... then I'm going to stick with this being a kludge of a solution to a mostly nonexistent problem.
Sorry, voltage drop is just NOT a reliable or useful method for detecting an unsafe situation. Voltage on home wiring can vary +/- 15V depending on neighborhood and local loads, at any time, without any unsafe practices or actual danger present. This is normal. Yet the Model S firmware will see some of these changes and just freak out.
- - - Updated - - -
One of the only reasons I'm continuing to reply here is to make sure that no one reads this and thinks that Tesla's current drop based on voltage drop is going to in any way even remotely protect them from any of the scenario's you've brought up. *That* would be unsafe, and not combating such nonsense would feel negligent on my part. Proper wiring, receptacles, OCPDs, etc are what will actually protect the premises wiring.... not Tesla.
