Bugeater
No problem. As the year draws to a close, please accept my (our?) thanks for the work you've put in to the app, and your willingness to share and accept feedback...
+10!
Hurrah for jpasqua!
Not sure I understand the sarcasm. What should I call it? OSX? Are you referring to capital letters versus lowercase? People generally understand the reference to either Windows or Mac (as did the OP)
+10!
Hurrah for jpasqua!
Slight simplification to the Windows Icon instructions:
When you right click on the VisibleTesla.jar, select "Send to... / Desktop (create shortcut)".
Saves a step or two.
Agreed, people understand it in the correct context. In an FAQ it should be written correctly as "Mac" - short for Macintosh as opposed to "MAC" - short for media access control. No sarcasm implied. Not sure who you're referring to as the OP. Joe wrote it correctly.
Hello Folks,
I'm updating the format of the documentation (and the content too) and I'm adding an FAQ. I'll start with a few common questions and answers, but I'd love some help filling this in. For example, I've already got two questions in there for which I haven't written the answers yet:
Anyone want to take a stab at writing those up?
- Windows: How can I get an icon on my desktop that will let me launch VisibleTesla?
- Mac: How can I get an icon in my dock that will let me launch VisibleTesla?
If you have any other tips/tricks/techniques/troubleshooting ideas or other content that you think should go in the FAQ, please send it my way.
Thanks and have a Happy New Year!!
Joe
I was hoping to get out a new release today, but I've been otherwise occupied and converting the documentation format took me (is taking me) longer than expected.
I wanted to give you a sneak peek at a couple of things:
- Here's the new style documentation. Each tab and other major topic has it's own page and there is the start of the FAQ.
- Here's a sample of the new output of the Trips tab. You'll notice that it now includes a graph at the bottom with elevation data, speed, and power usage corresponding to each map marker. If you select a marker on the map, it will highlight the corresponding items in the graph and vice versa. Check the documentation for more details.
- The trip can now export a file to Google Earth (a ".kmz" file). When you load that file you can see an elevation profile of your trip and do a pretty cool virtual tour. Here's a sample. Again, check the documentation for more details.
As soon as I can get some more testing of sleep mode done, I'll package up the release and get it out. You can see some of the other things that have changed in the preview of the release notes.
Steps for placing VisibleTesla on the Dock in recent versions of O SX (See also attached PDF for these examples with screenshots of every step)
1.Download VisibleTesla by clicking on a download link or automatically, with the “Check for Updates” feature in the Application (Typically a folder called VisibleTesla 0.XX.XX) will be placed in your Downloads folder).
NOTE: If when clicking on your VisibleTesla dock icon you get an error message that you cannot open the file because it is from an unidentified developer you will need to right click the VisibleTesla.jar file in its original folder and select “Open With” and choose ”Jar Launcher” [You only need to do this the first time. Subsequent attempts to open using the icon in the Doc should open the application without issue]
Not sure if this is a bug or designed behavior: If the car is sleeping when you launch VT, and you opt to not wake it up, the app terminates.
It would be useful for VT to go in to "slow poll" mode as it does when the car falls asleep after VT has been running, so that way you can launch it while you have the car parked, in anticipation of it being available to track trips later, fire off scheduled events, etc...
Using Windows 8.1 I don't see the option in properties to change the icon.Seems the least we can do:
For Windows 7 or 8:
- Install VisibleTesla as per the instructions included in the downloaded package. Make a note of the directory location where you extracted the VisibleTesla files on your computer (for example: "C:\Program Files\VisibleTesla")
- Navigate to the directory identified in step 1 above.
- Locate the file "VisibleTesla.jar". Right-click it and select "Send to... / Desktop (create shortcut)".
- Right-click the desktop shortcut you just created in step #3 and choose "Properties"
[*]Click the "Change Icon" button. In the resulting dialog box, click "Browse".
[*]Navigate to the directory identified in step #1 and choose the "FobIcon.ico" file, and then click "Open".
[*]In the resulting dialog box, choose the (only) Telsa Keyfob shaped Icon and click "OK"- Click "OK" again to close the Properties window
- You should now have a "Model S Fob" icon on your desktop that may be used to launch VisibleTesla.
- - - Updated - - -
nevermind. Instead of creating a shortcut I had just dragged the JAR file to the desktop. If you do that 1)You get an exception error and the program won't run, and 2)There's no option to change the icon.
When I followed the right-click/create shortcut option the above instructions work great.
Yeah, there's some weirdness in where you are allowed to run a .jar file from. Glad it worked for you...
