Wall Connector charging Question
I saw enough melted Leviton 240V outlets used for EV charging to upgrade to a Hubbell. The Home Depot Leviton is like $3 and the quality difference is dramatic. I believe Tesla has heat sensors in their plugs though so it would be very unlikely to melt, but considering the plug is in my attached garage the peace of mind of having a quality outlet is worth it. You can find lots of horror stories just on these forums alone.
More important is making sure that the outlet you have is correctly installed - and that means, for example, torquing the screws that clamp the wires to the manufacturer specs. My uninformed opinion is that the cheap outlets are much less tolerant of under- or over-torquing the clamp screws than the more expensive outlets, and most of the melting and smoke issues come from people / electricians who don't understand this. A bad connection creates resistance, which creates heat, which causes melty plastic bits.
There is no charging speed benefit for an SR+ using a wall connector vs using the mobile charger that comes with the car. The benefits (beside looks) have to do with the HPWC being rated for outdoor installations, and being able to share a circuit, which I think is available now.
Immediately after we took delivery and did a quick test drive of the P3… wife said the coolest surprise (in a good way) so far has been the HPWC opening the charge door without having to fiddle with the touch screen or app.
Congratulations! didnt know you had picked it up yet.
You might want to let her know that whether that works or not (pushing the button on the handle) depends on if the car is asleep or not. If the car is asleep, you will need to wake it up in some manner to push the button on the handle of the wall connector to open the charging door.
I usually open the rear door on that side of the car (or partially open it by pulling the door handle "some") to wake it up, then push the button on the wall connector to plug in.
Yeah they did the home delivery thing and showed up like super late lol. I didn't even take pictures since it was getting dark and the red paint looks kind of scummy at sunset hah. I've gone through most of the delivery checklist... for the most part I haven't seen the horror-stuff that some talk about on TMC.
The worst thing so far has been some plastic underbody thing on the rear of the car that they never screwed on... so it was dragging on the ground when they dropped the car off.
The most annoying part has been the amount of black fingerprints and smudges on the headliner, white dash inserts, metal bits, and white seats. Like holy crap... it's like they told a guy that used to work for a 1920 newspaper to drive the car for a few miles. Like wtf Tesla...
Make sure they know that ASAP!!!!
You don't need to open or pull on the door handle - just push in the fat end of the handle 1/4-1/2 inch (~1 cm) and it'll wake up the car without unlatching the door. It's still a mystery to me why I have to do that to unplug the car in the morning - seems like the charging handle should be able to wake up the car. Oh well, if that's the worst thing that I have to complain about I guess it means that I love my Tesla. ;)
Yeah, thats what I ment by "partially opening the door some" but I didnt do a very good job of explaining it, like you did. Thanks!
Just hold down on the button on the charging handle...
Reactions: mrau and Big Earl
I guess I’m impatient-three years of ownership, three years of cursing at Tesla (not really, but it sounds more dramatic to say so), and I never once held the button down for two seconds. I tried this morning and voila, the car woke up and the plug unlatched.
I learned something today; thanks.
Pretty sure this means the HPWC is a must-have accessory. NEMA 15-whatevers = lame.
Oohhhh so this push button thing on the plug thingie isn't unique to the HPWC?! But the HPWC looks so cool... it must have a special button 😿
Well, there *is* a reset button on the side of the HPWC, so maybe that's the special button? :)
All seriousness, your wife is right -- the convenience of having the wall connector right there all the time is pretty glorious! One of my wife's biggest concerns pre-delivery was the inconvenience of 'having to plug this thing in every day'... Once she did the 2-second operation for the first time, and realized it means you never.have.to.stop.at.a.gas.station.again -- well, that sold her right then and there.
And by the way, congratulations on taking delivery! Very exciting stuff; you're going to grow to love that car more every day. Enjoy the ride!
Reactions: Rocky_H
But we live in NJ with mandatory full service. It's so much better having to wait 5 minutes for the attendant to both start filling the car and another 5 minutes for him to remove the nozzle and process your payment. Or at least that's what my wife says every time I complain about no self service.
Reactions: dmurphy
It's really not about the speed of charging for me as both are adequate. It is about the cost of installation and which one is more reliable. For sustained EV charging at 32 amps, you need a high quality, industrial grade outlet which is $75-$100 (Hubbell or others). Most 14-50 outlets are not made for a constant draw like EV charging and residential grade for a washer/dryer. You also need a $45 Tesla 14-50 adapter. Additionally, some people (myself included) would want to purchase another mobile connector ($275) in order to always have the 110v mobile connector in our car at all times. At this point you are already over $400 in costs. The wall connector costs $500, looks better, is safer and less likely to fail (EV charging will melt the 14-50 outlet connectors after a few years, even an industrial grade outlet). The charging faster is just an added benefit. Couple that with a 30% federal tax credit available and the cost to install really is basically the same.
Great points. Also: the Tesla wall charger only needs two hots and a ground and has ground fault circuitry built in. The NEMA 14-50 needs two hots, a ground AND a neutral– plus a GFCI breaker in the panel.
Pretty sure the UMC works the same in this regard.
Yeah, that's not a wall connector advantage. The wall connector and mobile connector are identical in having the same special button on the charging handle that opens the charge port door.
My mobile connector is right there all the time on the wall too, and it's glorious. Again--not unique to the wall connector.
Reactions: dmurphy
For sure, but I park outdoors all year long.
Not sure I’d leave the mobile connector in the elements all year long, at least without a watertight enclosure. I mean, my brain knows it’s fine and all but there’s something reassuring about it being hardwired in some liquid tight conduit.
But yes — having a mobile connector right next to the car is indeed glorious!!
I built a solid enclosure for my 60 amp wall charger out of a single sheet of 3/4" plywood and mounted it on a 2' x 2' concrete pad. I also added a second 50 amp circuit with a NEMA 14-50 outlet for friends with non-Tesla EVs, plus a 120v outlet for vacuums and whatnot.
Is that an incandescent light bulb? 💡
