Ok, so we agree that your first graph shows about 11 kW. What does the last graph show, when you had the heat on but forced charging to be off?Sorry, this is confusing I think for folks that don't have a Sense unit and know what the different numbers mean. It also does not help that I switched from the web client app to the phone app and the two display data differently.
Now that I am back at my laptop, here is a graph (from the web interface) of the entire warming cycle from me going to lunch today. Looks like I gave it fifteen minutes of warmup time before unplugging it to leave.
The house was drawing about 1000 watts before I fired up the car heat (that is the red line at the far left of the graph). The overlaid graph of orange is solar generation - that can be entirely ignored in this conversation.
Then I have my cursor over the highest peak point which is 11664w at 11:57am. That is when I fired up the car heat. So I read that as about 10.5kW of energy being consumed by the car while the car was NOT charging (just warming). Even after the initial spikes moderate, it is still drawing 6kW or more of power.
They use the motor to heat the battery. The climate control is lashed to the interior climate control. It has nothing to do with it but appears to be the only way to the battery heating on (assuming u do not have range mode on)There is no dedicated battery heater in the M3. Ingineerix examination of engineering screens indicate that the battery may not be heated or cooled between -7.5º C. and 48º C ( 20 to 118 º F. ). It is doubtful that preheating the cabin has a direct effect on battery temperature.
I have seen 7+ kw drawn by the resistive cabin heater. That's very powerful when you consider it only takes about 17 kw to go 70 mph
Thanks, I see it now. Sorry about not understanding.When I said "first graph" I meant the first one in this post:
Warming the car and battery from shore power - 60a Wall Connector helpful
Not the first one at the top of the thread.
That last graph I posted here was the test where I set charging down low so there was no way it would kick in: Warming the car and battery from shore power - 60a Wall Connector helpful
I am pretty confident all this power draw is not going to battery charging.
None of these graphs show just 3kw of increase. They show much more than that. Look at the scale on the left.
The car doesn't need to taper the charge from it's onboard AC to DC charger until it is close to 100%. The charge taper is at superchargers.My main question (unrelated to heating) is why Sense can't identify the HPWC. I mean, come on. My charger kicks in at 3:00 AM every morning, and the draw jumps almost immediately from ~550W to ~12,000W. And when charging is done it almost instantaneously drops back. I've never charged past about 82%, so there is no tapering.
thanks for the explanation. Good to know!Then I have my cursor over the highest peak point which is 11664w at 11:57am. That is when I fired up the car heat. So I read that as about 10.5kW of energy being consumed by the car while the car was NOT charging (just warming). Even after the initial spikes moderate, it is still drawing 6kW or more of power.
Interesting. That's only a roughly 20% drop-off, so on a circuit limited to 32A it shouldn't start tapering yet (48A * .8 = 38.4A), and probably wouldn't until sometime into the 90's. Was the starting SOC around 72-75%? Eyeballing it (without opening the jpg in PaintX to count pixels) I'd estimate the tapering starter around 87% SOC, so maybe 92% or so is where a 32A (40A breaker) circuit would start tapering, assuming that taper remained that linear (probably a safe assumption here).Yeah, you would think the Sense could identify that easily (since any human can easily see what is going on).
The issue though as it has been described to me is that there is not really any easily identifiable spike or surge when the car starts charging that the Sense can easily key off of. Most of the devices Sense can easily identify have large inrush currents (like a motor or a solenoid). Or a ballast firing up...
The Tesla's have been built intentionally to soft start. They slowly ramp up their charge rather than engaging all at once. This is easier on the electrical system and the Tesla components. It is hard for the Sense to look for signatures over such a long time period of ramp up I suspect.
So I accidentally charged my car to 90% after messing around with the charge settings in this thread (I meant to set it back up to 80%). I noticed during that charging session that the charge tapered at the end. I thought that was interesting as I thought taper did not start till after 90%. (my Wall Connector is on a 60a circuit so it can supply a full 48a to the car) I wonder if this taper started earlier due to the battery not being warm enough?
The oscillations of the power draw are I suspect not from the heating components so we may just be looking at a battery replenishment cycle. If so, then a lower rated EVSE would just have a different cycle.
That's not much of a taper and would be none on a 14-50 outlet UMC 32 amp charger. 48 amp/240 is 11.5 kw which looks like where your chart is most of the time. The real tapering is from 120 kw superchargers after 50-60 % charge.Yeah, you would think the Sense could identify that easily (since any human can easily see what is going on).
