Does Waymo have an issue with hiring good safety drivers? Or maybe it's difficult to transition from monitoring an autonomous system for several hours to driving manually?
Statement from Waymo PR about another incident where a vehicle was being driven manually:
I suspect the latter. Making that transition from monitoring autonomous driving for hours to driving manually can be difficult, especially if the autonomous driving worked really well and did not require any interventions for hours and hours. It requires two very different skill sets. In one case, your focus was not on driving but on checking the systems and checking for any possible issues. That's very different from manual driving where you have to monitor the road and other users and do the driving tasks yourself again. And the safety driver may just be a little tired from monitoring the car for so long or maybe the safety driver lost focused a bit and did not see the pedestrian.
I am sure Waymo will do a reconstruction of the accident in their simulations. So Waymo will have data to show if the Waymo Driver could have prevented the accident or not. Also, we need to know why the safety driver was driving manually. Was it following a safety disengagement? Was it because of a situation that the safety driver thought the Waymo Driver could not handle? If the Waymo Driver can handle it, then I don't think the safety driver has any business driving manually.
But I think it begs the question: at what point is the autonomous driving good enough that having humans drive manually is less safe? I mean, if the data shows that the Waymo Driver would have prevented the accident then perhaps, having safety drivers driving manually, is making the cars less safe, and Waymo should remove the safety drivers, at least in the areas where the Waymo Driver is very experienced. It does not make sense to me to tout that your autonomous driving is so safe and then get into accidents because you are not using said autonomous driving.
After all, we keep talking about how autonomous driving will be better than human driving because autonomous cars won't get tired or distracted. So autonomous driving will prevent accidents caused by humans. If humans are driving your autonomous car and causing accidents that the autonomous driving would have prevented, it would seem that the answer should be to remove the humans from driving. I would ask the question, why are the safety drivers driving manually at all since it is a L4 car?
Now, if the Waymo Driver is not safer than human driving and Waymo really needs safety drivers to prevent accidents, fine. Then, I think they should revise their safety driver procedures. Maybe reduce the number of hours that safety drivers have to monitor the car to prevent fatigue or change the procedure for when they can transition to manual driving to make it easier.
