These are hypothesized numbers. I am asking for real numbers read from the meter in your (or anyone else's) car.
Actually, they are numbers I saw every time I filled up for years in a previous ICE compared against numbers I see every morning in my current X100D.
It should be clear that I am, informally, using scientific method. It started with the observation that there was a spike at the beginning of trips that was bigger than the spike in leaving a stop sign. This led to the formation of a hypothesis that the trip meters were accumulating energy usage before departure. That was followed by recording data from trip meter readings on actual trips. All my recent posts on this subject have been reports of what those trips showed and whether they support or refute the hypothesis. So far they are supporting it. It seems that you are the one evoking theories while I am actually going down the scientific method path.
If you are familiar with the scientific method you know that you can prove nothing by its use but only show that the null hypothesis is true with low probablity.
None of this means that your thoughts are not of some value.
The surest way to gather control data would be to quickly reset a relevant meter at a stop sign. You haven't done that and keep brushing similar suggestions from others off as well.
That discussion aside, here are some real numbers from a recent trip I just happened to remember to pay attention for:
Outside temperature: 55 degrees F
Time X100D parked: ~5.25 hours
Regen availability: ~50%
Accessory state: Range Mode OFF (always), Media PAUSED (Local USB), HVAC OFF, ??? ??? (maybe driving lights were on, I don't know, shouldn't really matter in this scenario)
Given the above variables, I got in my X100D and immediately put it in drive to start a trip. I gingerly accelerated down a mild but noticeable incline, up a more mild / less noticeable incline of slightly more length, and then began to coast down a hill to a stop sign. Between the end of this incline and the start of my coasting, my first reading came up:
726 Wh/mi with .1 mi logged
Shortly before I stopped at the stop sign at the end of this short downhill coast, the reading changed:
242 Wh/mi with .1 mi (still) logged
I was fortunate that there was no traffic, and I was able to immediately turn onto the highway and begin accelerating to 55 MPH at a rate that is certainly slower than the average driver (not to mention the average Tesla driver). When I reached 55 MPH, I looked at the meter again and had the following reading:
782 Wh/mi with .3 mi logged
From there as I watched, the meter, this reading slowly decreased (it was down in the 600s while still reading .3 mi).
Perhaps the problem is that you are treating the .1 mi reading as a precise reading in your math even though you have already acknowledged that it is obviously rounded most of the time.
The fact that a 726 Wh/mi reading was followed by a 242 Wh/mi reading while the same tenth of a mile was displayed at the beginning of a drive seems like pretty solid evidence against any "departure tax" accruing during the 5.5 hours I was parked.
The fact that a higher reading was shown after a subsequent acceleration at .3 mi than the first reading at .1 mi also seems like pretty solid evidence against the very same.
The experience to know that if I drove 10 miles and came back to that exact same stop sign and took out the exact same way, the reading would not have jumped on that acceleration seems like pretty good support for the suggestion that the data used and averaged together starts when the trip starts (at hh:mm in "Since hh:mm").
The fact that I have observed average MPG meters in ICE vehicles behaving the exact same way for decades seems like pretty good support for the not-so-hypothetical scenario I previously laid out.
