I noticed that they sell a pretty pricey cover for the hole in the undertray - is that included in the hitch receiver product?
They also make bike racks that hook onto the trunk too...
Edit - not specifically for the Model 3 but I would imagine they would work
Agree on all counts. I'm not one to keep my bikes or cars in pristine condition but I can't imagine putting a trunk rack on a $50k car. You're guaranteed to scratch your car and your bike.I would generally advise against this for multiple reasons.
- Trunk racks make contact with your paint.
- The presence of a bike on a trunk rack prevents use of the trunk.
- These racks typically don't extend far enough away from the vehicle to prevent pedals from contacting the bumper in all scenarios.
- Trunk racks do not hold bike as securely as newer hitch rack designs which clamp bicycle wheels.
- If you care about your bike do not clamp it by the frame (also wacky full suspension mountain bike frames).
Edit - Added #5 but I'm a minority who has bikes worth more than his current car.
I did it as well Randy this weekend and similar to you because of the stupid M10x1.25 nuts it took 5 hours instead of 2. That said I thought the instructions were good, and I thought they said to cut 2 4" holes which worked out well for my hitch install. I also agree a list of tools would be helpful and I would add ramps or jacks as the underbelly bolts are not easy to reach. I thought the hitch was quite solid and I like how it attached to the car. The rear of the Model 3 is much more solid than the rear of my Volt, which I nearly pulled apart when I pulled our camper across the Rockies several times. Thank goodness for small town weldersOK, got the hitch finished. Had to take the car back apart as I didn't connect the sensors on the back bumper and didn't cut a big enough hole to get my hand thru to add the hitch to the mount.
It's a LOT faster to do the second time. Sadly you start thinking you can put it together in any order, turns out that may not be true. Ended up putting it back together 4 times including the time I realized I had AGAIN forgotten to attach the sensor cable.
Cutting the hole bigger in the belly pan was easy, a utility knife just goes right thru the plastic, and I used the hole saw to expand the size of the hole over the single hole I made yesterday.
Still need to wash the car now. Get the bugs off.
Very happy with this adventure. Cannot wait to have someone else do it, to compare notes.
-Randy
I was wondering about this after seeing other cars with similar hitches. Seems like it could do serious damage to the car if you were do that with any speed. I'm hoping Tesla has a factory hitch option that moves it up higher. It would probably be easy to modify the Torklift hitch to be higher but getting the bumper cut to look good would be tricky.I have a hitch on my other car and when I back out of the drive it scrapes. Now when I back into the driveway the Tesla hits and STOPS. Probably not going to keep the hitch on the car all the time, but I can also approach the driveway at an angle.
