jgs
I suspect you couldn't regen nearly enough to be concerned about overheating that 1200 lb mass in any reasonable time period... unless you were coasting down from the top of Everest...
And of course, after the first few miles of descent, you'd be putting the power into the pack instead of onto the pack, so to speak.
And to be quite honest, I'm not sure how much faster you'd really be able to heat a cold pack up with typical regen during normal driving... the main advantage might simply be not having to lose the braking feel when you let off the accelerator...
Preserving braking feel would be quite nice, but once again, does suffer from the drawback that the solution doesn't work for a 100% full pack. A cold pack will become a warm pack within not too many minutes of driving, whereas a 100% full pack could remain 100% full for quite a while if descending a mountain. (Not that this is a problem for me, for the most part, although the cold pack is.)
