MarkS22
The other constraints you didn't mention are adequate resolution, update rate, and sensitivity/dynamic range on the camera (though you kinda hinted at the resolution limit in your followup.) In theory it's possible with one camera, in practice I think it'll be quite a while before a practical one camera solution exists.
Well, yes, that was my "simple" answer. Resolution, frame rate, and dynamic range are all important. I believe the EyeQ series maxes out at 36fps, but I don't know where the resolution tops out at that frame rate. (I don't know its maximum bitrate.) In terms of dynamic range, that's getting cheaper and better every year. It's one of the reasons I prefer they wait longer for AP 2.0 hardware. If the software/regulatory isn't ready, let the cameras get better in the meantime. For example, 12-14 stops of dynamic range at 4K running at 60fps should be very reasonably priced in two years. I'm talking GoPro level sensors at that point. Not high-end Alexa or RED sensors. (Of course, two lower cost camera sensors, side by side, one with a neutral density filter might be a better interim solution for dynamic range.)
So, I don't disagree but the simple answer is: a single (good enough camera) with the right processing and software can see a stopped car.
