What size PVC will the UMC wand fit through?
Discussion in 'Model S: Battery & Charging' started by hingisfan, Jan 25, 2015.
  1. hingisfan
    hingisfan hingisfan_Mark_V
    Kingston, Ontario
    Hi guys,
    Changed my mind on the wall mounted box for my semi-permanent UMC setup. Going to put the Nema 14-50 outlet on the inside of the garage, then run the wand thru a hole with PVC. I don't pickup the car till later this week, and my guy is coming tomorrow to run the electrical. What size hole/PVC do I need? 2 inch?
    Thanks
  2. jcaspar
    jcaspar Member
    Sacramento
    For Sch 40, 3/4 " should be enough per this chart but I would go for 1", especially if it is some distance. 2" conduit is massive, way bigger than needed.
    See this chart:
  3. hingisfan
    Kingston, Ontario
    I need the UMC wand to fit through the hole. I don't think wire size matters as it will be smaller than the wand head.
