I'm not sure what you mean. I've gotten 119kW many times in my 2013 P85+. The difference is I don't hold that rate very long, only from very low state of charge to about 35% whereas the Model 3 will take that rate for much much longer up to a higher percentage before it starts to taper down as the battery fills.I know the M3 can take it, but most Gen2SC' are 120KW max, and you pretty much took it all - no? That I haven't seen. I think this is the record high for m/hr charging.
/edit If you're talking about the miles per hour charge rate, that's kind of a placebo number that doesn't really matter. You'll never get the amount of miles it says you will, it just says if somehow you could take 119kW for the duration of your charge (you won't) you would get that many miles. It all depends on your average wh/mile and every car/driver is different.
