Thanks! Look forward to your feedback.
Ok, tested it on the way to work and no sound like in the video. I've only got 845 miles, so who knows if it'll show up down the line. I'd say it's not normal.
Thanks for the feedback. I dropped off at SC this morning and they gave me a Model S loaner. It's super quiet and I can barely head motor even during acceleration and Regen braking...I mean it's night and day vs. what I'm hearing in my car. Should a model S be that more quiet or should the motor noise be similar?
There are already several threads about this sound, presumably inverter whine. Mine is quite subtle and between 38mph and 48mph. Someone else posted a clip of the sound just a day or two ago. Make sure your tech is fairly young, as their hearing is typically better than us older folks.
The S uses in an induction motor, whereas the rear motor in a Model 3 is a permanent magnet motor, which inherently is a noisier motor in this regard. The 2013 Model S 85 loaner with 60k miles they gave me was silent compared to my LR RWD 2018 Model 3 with 23k miles.I haven't driven in an S, but my M3 is close to what you're describing. I hear it while accelerating, but it's very muted overall.
I cannot wait to hear what the SC told you. If it's anything different than what mine said, I'll be livid!Thanks for the feedback. I dropped off at SC this morning and they gave me a Model S loaner. It's super quiet and I can barely head motor even during acceleration and Regen braking...I mean it's night and day vs. what I'm hearing in my car. Should a model S be that more quiet or should the motor noise be similar?
This was what was in my invoice, including my statement of the issue:
Concern: Noise & vibration - other - customer states: I have a high pitch whining sound coming from the drive unit while
cruising/maintaining speed between 25 and 50mph.
Tesla: Test drove vehicle, was not able to verify any abnormal noises, Test drove vehicle with similar build to compare and both
vehicles operated the same. Nothing to further address at this time.
Hey Folks! I'm a new to Tesla and so far on my AWD I'm hearing a whining noise (high pitch) when cruising (light pressure on accelerator), especially when going 35-45mph...I also hear an intermittent pulsing / oscillating sound from the front motor (I believe some refer to this as "Beeping"). Really annoying. Sounds like someone is blowing through a whistle. I cannot believe this is normal but wanted to check if anyone else hears the same or should the motor be mostly quiet under low load while cruising at constant speed?
If it's there, it hasn't been noticeable enough to catch my attention. At highway speeds, the sound of the tires will drown it out. There is a nice stretch of road (speed limit 45 mph) before the highway I can test it on.Do you hear it while cruising (not accelerating or Regen braking)?
That was me. The video is linked below. The SC told me to pound sand. They don't care about the pitch/frequency of the noise. As long as the vehicle sounds remain within a certain decibel range that Tesla Engineering intentionally made a wide range, then there is nothing they will do. Folks like us who either A) have super sensitive ears or B) have slightly noisier/whinier motors/inverters will just have to suffer. Pretty pathetic if you ask me. Spend $56k on a vehicle to be bothered by the piercing sounds it makes. From an annoyance level, I equate it to the sound of nails on chalkboard.
VID_20200605_064939~2.mp4
That's the normal sound. It does away (gets drowned out by tire noise) when speeds exceed about 20 mph.
That is definitely not normal. That almost sounds like air blowing past an obstruction causing the whistling. If that's from the motor, that can't be right. I also didn't hear any sound like that when I test drove the show room AWD.
I might have something different. I don't hear the motor much (other than acceleration or Regen) under 20mph. It's when I get over 30 and really into the 40s and higher that it starts to get really loud. On the highway, it's still there, but performance tires and wind overtake it.
The video doesn't capture it like it sounds in real life but my car didn't always make this sound. It's slowly has been getting louder and louder.
@rorrim - I did not drive in another new Model 3, but I have driven in two coworkers. One that is 27k vins away from mine, same build, sounds almost identical and he states his didn't always make the noise either. The other coworker has a AWD and is 400k vins newer than ours, and his does not make a peep. The AWD has only half of the miles that we have though.
Here is my post on the other thread with all of the details:
High pitched noise from drive unit
No, as I said above they said it was normal.Did Tesla acknowledge it as an issue? Do anything to resolve?
