More the better I guess; I dunk/rinse it off after doing a small sectionHow often do you have to dunk the nanoskin? If you my dunk often enough, same problem can happen with it?
Definitely different than clay but also better in every way IMO
Personally the fact that the contaminants stay embedded in the clay is a negative for me as it’s just an opportunity for them to later on scratch the surface, even if you are folding it over and over. With Nanoskin you dunk it in water and they’re off for good
I’ll stick with the Nanoskin, has only done me good and is faster and without a doubt does not mar the surface like clay.
I couldnt really care less what contaminants there are, just that they’re all coming off and along with using an iron remover (chemical decontamination), the clear coat is then free of contaminants and ready for paint correction
I like Iron X from CarPro and spray it liberally all over after mechanical decon (Nanoskin or clay). You’ll see it turn any embedded metal spots purple and then you rinse off the whole car.Which iron remover do you use? Do you apply the iron remover to get rid of contaminants after rinse and foam wash and before the nanoskin? I assume after nanoskin, you apply a layer of wax?
If there is no paint correction or polishing to do, then do an IPA wipe down to make sure the surface is ready for sealant, wax, or coating
Mainly because the iron x will remove more after other surface contaminants are removedAny reason why you would not want to get that decontamination off the paint before clay bar? Seems like if you can get rid of the contaminants and then rinse off before clay bar, why not?
So many things may...may have adverse effects in a marriage though.
I'm not comfortable taking my baby to the local car wash because I see them use the same rags on multiple cars and some roll out of the car wash still with dirt. I've yet to find a decent hand wash place in the DC area so I figured might as well learn to wash the car at home. It will take me 40 minutes to drive someplace, have them wash the car, and drive back home but I'm thinking in less time I can wash the car on my driveway!
So far what I've gathered is that the best approach is the two bucket method with something called Optimum No Rinse but they have several different types and I'm not sure what to get. Should I get the blue type or is there something else better?
I'm still looking for a paint protection file option at a reasonable cost in the DC area so the car is not protected by film so I want to safely get all the dirt off the paint and add a protective layer that is safe for the clear coat and makes the car shine.
I'm looking for a list of things to buy starting with the two buckets, microfiber, proper washing mits, etc., so please share your advice, recommendations, and your favorite videos! Also looking for a quality interior cleaner for the dashboard and a good quality leather cleaner and conditioner. I'll post a photo of the washed car after all the advice![]()
Meguiar's G17516 Ultimate Quik Wax is a spray mist on wax/cleaner that works very well. Used it for a year now. You'll need to buy a few microfiber towels. If the car is very dirty just hose it off first. You'll need to change towels as they become soiled to prevent scratching or a film on the surface. It works well on the finish and glass. Be sure to wash the towels in the washer after each use. Cost about $9
Been doing it for years and there is no issue with it, low to no heat and the towels tumbling on themselves is not going to harm them in any fashion
Anyone had any experience with Meguire’s Water Magnet drying cloth? Will it scratch a ceramic coating? Is it as safe on the finish as microfiber?
For windows I would save your old clay and use that.
