that seems lowI topped out at 8.1kW today @ about 11am. Just wondering what you all have seen with the newer 16.2kWh system in comparison.
that seems low
I have an 11.8 kW system and I hit 6.5kW at noon. Which direction do your panels face?
ya, mine are mostly NW facing. I'll call Tesla on Tues to see what's going on. Just one challenge after another with this installation.
@socaldave what software did you use to build that spreadsheet?
I didn’t know that about the app thanks that’s handy.Just the export from the Tesla app.
Did you check to make sure both of your inverters are producing power? You can move the red switch to P for 2 seconds and see what the LEDs show - Inverter Status and System Performance Indications | SolarEdge
Or you can use the MySolarEdge app and view in read only.
My install has a single 10kW inverter. My 12.24kW produced 58.1kWh today. You don't have trees or anything which would reduce your production, right?
correct, nothing blocking.
Are you talking about a 16.2 kW system?I Just wondering what you all have seen with the newer 16.2kWh system in comparison.
I reset the breaker and was able to connect to both inverters finally. One inverter only generated 20kW today. The other did 35kW.
Are your panels east facing? Majority of mine are mostly west facing and I hit peak of 9.2kW at 2:30 for my 12kW system. Something definitely seems off with the amount of generation. Almost like only 1 inverter is not producing/reporting.
Heavy layer of dust? Hazy / humid air? Super hot temps?
All of these negatively impact production.
