I am guessing the small gap between the chrome and plastic is small enough to cause this issue. There is no noise at slower or faster speeds. Anyone else experiencing this? Trying to figure out how to fit it. Every annoying.
Hi mate. Did you find a solution?View attachment 389684 From day one owning the 3 (about 30 days), when I go 40 to about 55 mph, there is a whistling noise coming from the drivers side mirror. I have isolated the noise coming from between the chrome and bottom of the mirror housing. While driving, if I place my finger on the edge of the mirror housing to where I am pointing, the whistling stops.
How did you test it?Wow! Now i know where this noise is coming from. Thanks!
Nope. Don’t want to force anything into that gap. It is where the housing pivots. Any ideas from your end?Hi mate. Did you find a solution?
Best regards
Toke
While driving, reached out and put my finger where I am pointing to in the picture. Noise stopped.How did you test it?
Just few days ago, my car now has some high pitch whistling too on the driver left side, occurs when I'm at 60-75mph. I was annoyed because the pitch is intermittent...Is your intermittent at the same high speed? Time to check on the mirror.
I had this early on. Always started at 40mph for me. They wound up popping off the mirror cap and adding some silicone and felt. Others have reported receiving an entirely new mirror housing. In either case schedule an appointment from your app, should be pretty straightforward.
You can turn off the "mirror fold on lock", I think? Then you could use some of that black foam beading to fill the gap.It is where the housing pivots. Any ideas from your end?
I have similar noise while driving through a quiet forest road, at approximately 35-40 mph, on the passenger side because I had those windows down a little bit. It disappears at faster speeds. Not sure if I'm going to do anything about it; I'm sure they are not going to hear the noise when driving on local roads with other cars around.
*¯\_(ツ)_/¯* Still an option, but sure a trade-off you'd rather not make.I like having the mirrors fold when I leave the car so that is not an option. At $50,000 the mirrors should not whilst and be functional.
