Go to the Lucid website, this is a Tesla websiteThink the pressure is a factor into efficiency which along with Lucid and now Hyundai/ioniq6 lead rhe industry
What’s Lucid guidance with psi on their vehicles?
In contrast, the Hyundai Ioniq5 and Kia EV6 tire pressure recommendations seem to be 34-38psi, depending on 2WD/AWD and wheel/tire size.Lucids tire pressures from their owners manual
These high pressures are def an EV performance and efficiency need
I put CrossClimate2s on my Model 3 LR RWD a couple of years ago. I didn't keep track of my Wh/mi consumption before and after, but it seems like it went up after replacing the OEM Michelins.Interesting about the cold weather making the liner stiff. I got the car a couple months ago so I haven't had a chance to see what it's like in warm weather, but I'll be looking out for that. And yes, the MXM4 do not feel impressive in any conditions, they seem completely focused on efficiency. I am also a Michelin fan, usually Premier A/S on the family car and Pilot Sports on my fun cars.
Funny you mention that you did an early replacement of the MXM4s with CrossClimate2s - I was just on TireRack doing some research with the same idea in mind! The CrossClimates get incredible reviews everywhere you look; they seem to be the new all season king. However, this (incredibly relevant) TireRack test did put a damper on that idea a little bit - they used a Model 3 to compare the OEM Tesla MXM4 vs the CrossClimate2 and found that the CrossClimate2 is a better tire in almost every way, but that you pay for that in a significant range hit.
It made me a little hesitant about ditching the MXM4s since I was hoping to do some road trips this summer. It'd be a bummer to lose 10% of my range just to tires. Have you had the CrossClimates on a road trip?
Running at higher-than-recommended or tire max pressures…any untoward center tread wear as a result?I ran my Chevy Volt tires at 50 psi. …50 psi for my 2015 Model S…have run my Model 3 at 50
Lead the industry? Neither of those cars come close to the MPGE of my 2021 SR+.Think the pressure is a factor into efficiency which along with Lucid and now Hyundai/ioniq6 lead rhe industry
eMPG? In the U.S. I'm pretty sure it is expressed as MPGe. Where are you from? Have you actually looked at those values for the vehicles cited?Lead in vehicle efficiency, eMPG
I took a definite consumption hit when I switched to the CC2s - about 10-15 Wh/mi. This hit has been widely reported here in multiple threads. Seems like the original MXM4s get the best mileage (based on my arbitrary and unreliable memory).I put CrossClimate2s on my Model 3 LR RWD a couple of years ago. I didn't keep track of my Wh/mi consumption before and after, but it seems like it went up after replacing the OEM Michelins.
And how is what you said different than what he said?Not true. Max pressure is max COLD pressure.
I don't see how those two are related.I kept my tires at 42……and I was blessed with replacement at 22K miles.
Shortest life on tires ever for me.
None. I read websites promoting higher pressures for efficiency, and they claimed that modern tries don’t wear in the center like old bias ply tires do. Even at pressures somewhat above the max pressure on the tire sidewall.Running at higher-than-recommended or tire max pressures…any untoward center tread wear as a result?
Lucid recommends 49psi for 19”s, so I would say it’s fair to assume that the higher pressures you’re running the better your efficiency, within reason.my bad MPGe
Im front earth.
Yes, they lead the industry
I don’t understand the question?
Every car manufacturer has various tire suppliers and recommends the same pressures for the same tire size. It’s mostly a factor of desired rolling resistance and rolling diameter and suspension tuning. But even then a couple PSI is not likely to make a noticeable difference.
That actually makes a lot of sense now that you mention it. So since the weight of the car is constant, the contact area is inversely proportional to pressure. But what about the pressure due to the elasticity of the tire itself? We can inflate a tire to 40 psi even with no weight on it.
