Thanks guys. I think this makes more sense as I believe I might me approaching my 100 panel's limitations.It isn't necessarily a wiring problem. I had this happen at two houses now. One I had an electrician do the 50-amp outlet, the other I did it. Basically if there is any sort of brownout during charging the car will reduce the amperage. I keep mine at 38amp and it stays there pretty well.
I'll do another search for more info. I tried that first but I guess I was wording it goofy.
Yeah, it happened to me again midday yesterday with basically nothing else running in the house. Hoping it's ComEd because I'm otherwise baffled. The electric work was done tight and by the book, permit approved and all. Central A/C is the only other high draw appliance (natural gas range and dryer) and again, that stuff was all off while I was only achieving 30 amps while charging.That could be the case, but it just happened to me at my new house with a 400A panel... I know it wasn't overloaded (at night) so it was likely a small power drop from the power company.
Will do. Just to echo the sentiments of most folks perplexed by this issue, I can get by fine with 30 amps 90% of the time, but it's irksome not getting the 40 that you expect.As cynical as it sounds, @SabrToothSqrl is basically right. I have seen several threads of people trying to chase this down. Try it around 35A or so. With less draw, it will not be pulling on the voltage quite as hard, and it may be able to stay up and not get interrupted and cause it to kick in that safety system.
Eh, like he/she said: blame the power company, and just add it to the list. The stop lights are longer than we would like, the traffic is more than we would like, food costs more than we would like, etc. Things aren't perfect.Will do. Just to echo the sentiments of most folks perplexed by this issue, I can get by fine with 30 amps 90% of the time, but it's irksome not getting the 40 that you expect.
That's kind of a strong statement. Most UMC use is everyday charging. Mobile is a capability, not a requirement.It was the UMC - they were not designed for everyday charging (on terms of durability).
