Rashomon
This is consistent with ICE findings from BMW testing done some years back when they were evaluating optimal fuel efficiency in acceleration in connection with meeting fuel economy standards. I do not have the data they released anymore but i clearly recall the results: accelerating at about 2/3 throttle produced the best fuel efficiency. At the time teh test was made with both then-current production diesel and gasoline models, which astonishingly (to me, anyway) showed the identical 2/3 throttle for best acceleration efficiency. They also demonstrated another ICE point made here that the most efficient thermodynamic cruise is maximum torque. The latter point totally ignores aerodynamics, which are more important than are thermodynamics above, IIRC, 80 kph.
I never saw any BEV comparable data, but based on posts here and elsewhere, I suspect that battery temperature rise and absolute level is more of a factor than the actual acceleration rate in acceleration efficiency. However, overall BEV efficiency has all the passive losses, transmission/conversion losses as larger factors than pure acceleration rate.
Lacking any specific data, and not being an EE I have no technical qualification for my last point, the underlined part. Am I missing the point, or are BEV's inherently less sensitive to acceleration rate than are any ICE?
No, you are exactly right. ICE engines are most efficient unthrottled (i.e. full throttle), except most engines have their mixture go rich at full throttle for cooling, both to reduce the chance of detonation and to protect exhaust valves, etc. So the most efficient power is usually made at a throttle opening approaching full throttle, but not close enough to to get into the rich part of the fuel injection map. (This part of the map is almost never engaged in emissions tests, or it wouldn't be able to exist!) Best brake specific fuel consumption (BSFC) is almost always near peak torque rpm; go faster and power increases but so do friction losses. There can readily be a factor of 5 difference in efficiency between peak BSFC and BSFC at, say, 5 percent engine power. This is why best range with an ICE vehicle is usually obtained somewhere around 50 mph. That's where the improving efficiency curve of the engine meets the V-cubed nature of aerodynamic drag. Go faster than that in an ICE vehicle and range drops, but because efficiency is still improving with increasing load, it's nothing like the drop in range of an EV as it goes faster.
Because EVs have such a high and flat efficiency, acceleration doesn't matter much, but aerodynamics and speed matter tremendously. You're seeing the actual energy requirements of moving the car down the road, not a reflection of the engine efficiency map.
