Did it last long enough to leave a spike on the intra-day chart in the app?Actually I am on cost-saving mode so the house after 3 pm should use PWs power, that is ok, I am just confused about why the PWs send power to the grid that should never be the case in any mode.
also, it happened for a few minutes so i didn't get the chance to check the meter outside. It could be just a bug in the app I don't know.
NoDid it last long enough to leave a spike on the intra-day chart in the app?
I think it is a temporary issue in the display only. I see it sometimes very briefly, but then corrects itself
I can play the Watts up game (ie turning on and off appliances/devices) and I see about a second lag at most with my app.And I've noticed what the Tesla phone app displays can sometimes lag the actual Powerwall (if you check via the gateway local website) by any where from a few seconds, to minutes - which can be disconcerting.
Mine is connected via wi-fi and of course cellular.
I often find I cannot reach my PW gateway via my local net and browser. It may be my situation where the gw is attached to a bridge like device. I can see the pw gw in the bridge but for some reason it does not get the IP address from the access point. For this reason I cannot depend on using it for any API features until I get this figured out.Maybe 1 day out of 15-20 days, an automated API configuration change pushed to the PW won't go through as scheduled, and often that's also when I notice a bigger difference in the sync of what the two views are showing.
I am using WiFi but through a very powerful access point linked to the house router via ethernet.
The problem may be in that the "remote" AP is just passing through the IP address assignment to the router and there may be some hand off issues there. The signal strength is very good.
I may have to look at assigning the IP address of the GW permanently via the setup (if possible) rather than having the router set it's fix IP address via the MAC address.
OK. I have seen this now. Interestingly the real time flow seems OK but the SoC seems to be off. Also interesting is that the SoC was 60% (my reserve level) when I checked after peak stopped the night before and the PW were no longer discharging. You will notice one is 54% and the other 57%. I guess this is either vampire drain and/or the latent temperature of the PWs.And I've noticed what the Tesla phone app displays can sometimes lag the actual Powerwall
