AlanSubie4Life
Efficiency Obsessed Member
The difference in efficiency between P3D & P3D+ has to do with the different wheel more than the different tire compound.
If you look at Troy's calculations, there is a 7% different between the areo wheels (without the covers) and the sports wheels even though both are on all-season tires. This is mostly due to the weight of the wheels.
Tesla Model S/X/3 range at 55/60/65/70/75/80 mph
The tires are both all season, but they are not the same tire manufacturer. You'd have to use exactly the same tire compound to control the experiment to check impact of the wheel size. If anything, I think this 7% projected impact shows that the specific tire matters a lot.
https://www.tirerack.com/tires/tire...&tireModel=Primacy+MXM4&partnum=345VR8MXM4PV3
https://www.tirerack.com/tires/tire...reModel=ProContact+RX&partnum=34WR9PCRXXLCOSI
FWIW, the Tire Rack specifically calls out low rolling resistance for the MXM4 but not for the ProContact (though I am sure they aren't bad).
On my Spark EV, I experienced about 13-20% range reduction when going to RE-71Rs from the stock Ecopias. This is an extreme case. However, nothing else changed - wheels are the same - (and I have two Spark EVs, one with the stock tires, and one with the sticky tires), so it's relatively easy for me to see the (large) difference.
Certainly a little bit of extra wheel weight (looks like 7lbs per wheel for P3D/P3D+ difference) won't help, but rolling resistance and stickiness is very likely the main contributor to the efficiency loss. It would be great to get firm data, but it is hard to control the experiment. Estimate is 10-20% loss, but usually people change the width, the aspect, diameter, the wheel, aeros, driving habits, etc., so it's hard to control for all the variables.
The good news is that there is a huge stopping benefit & handling benefit to going to Summer tires.
