I am absolutely positive that the range increase is only a number change and not an actual increase in efficiency.If this range increase for LR RWD turns out not to be BS, I’ll likely pick a set of the foam-equipped 235/45s to replace my mxm4s in a few months. Should basically balance.
I guess we will see. By BS you mean, not an actual range increase? I kind of feel like most people agree it is not an actual range increase (if it were, all Model 3 variants would have somewhat better efficiency). Just aligning with the EPA numbers. But who knows, I guess.
Those PS4S tires really grip, I love them, but the hit on efficiency will be considerably larger than the “increased” rated miles.
If I were you, I would budget for a 15% hit, to be perhaps a little conservative.
I like the look, but that's a bummer about the weight showing you down.Update on the Conti 255/40/19's, took out the car on empty roads tonight and it is official, I have neutered my 3, dragy shows 2 tenths off 0-60 and although the tires are new with only 20 miles stopping is about the same at 118 ft., i'm sure after a 1,000 miles stopping will improve but it has lost a little punch from the heavier larger tires.
I thought I was only adding about 2 lbs. per corner but wheels were powder coated and because its a total of 4 coats and it looks like they laid it on thick I got an increase in weight of up to 2 lbs! on just wheels, I weighed them at anywhere from 26.2 to 27 lbs. per wheel sans weights! total package was 53 to 54 plus lbs.per wheel, I was shocked! well I like the looks anyway and I guess if I really wanted to go fast I should have got the P3D!
Can 265 tires fit on the stock aero wheels?Alright I ordered a set of 235/45/18s super sport 4S with the TO marking and the quiet foam for the fronts and 265/40/18 SS 4S for the rears. All going on stock aero wheels. Will post pics once its all mounted up.
They WILL fit but anything wider than 255 is against manufacturers recommendations for an 8.5" wheel width, it doesn't stop some people from doing it and most say its fine but....?n 265 tires fit on the stock aero wheels?
According to Tire Rack, the specs for the PS4S say 9.0-10.5" rim width. Tesla Aero wheels are 18x8.5". The OP has not posted pics of them installed yet.Can 265 tires fit on the stock aero wheels?
Your 255 tires are also probably about 2% smaller in diameter. It's quite possible that the power control from the 3 is limiting max torque by limiting what it thinks the wheel speed is. It'd be interesting to get tires that are slightly larger to see if they help the externally measured 0-60 times.Update on the Conti 255/40/19's, took out the car on empty roads tonight and it is official, I have neutered my 3, dragy shows 2 tenths off 0-60 and although the tires are new with only 20 miles stopping is about the same at 118 ft., i'm sure after a 1,000 miles stopping will improve but it has lost a little punch from the heavier larger tires.
When I picked that size it was because I did not want to go smaller, I was originally going to go with the 245 but wanted as much curb rash protection as I could get after the wheels were powder coated, 245 is probably the sweet spot.Also, when Tesla tested their car on the track a bit ago during the announcement of Track Mode, they tested with 245 width tires, which would be a slight increase. So, maybe there was another reason for that, to extract a little more power from the car. What do you think?
Pilot Sport 4 or Pilot Sport 4S? I didn't realize Michelin sold the PS4S in TO spec in anything other than 235/35R20.235/45/18 with the TO foam is what i ordered
