Tirerack has been having a closeout on these for the longest time. Except they say "Front Fitment no longer available" which is their 21"x9 ET40. Is there anything stopping me from just using what they recommend for the "rear" fitment, which is 21"x10 ET40 in a square setup? I dont think theres any clearance issues right with using the 21x10 in the fronts as well as the rears? Seems like a crazy good deal for a fun change of wheel. $636 for 4 wheels. https://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&autoMake=Tesla&autoModel=Model+S&autoYear=2015&autoModClar=70D&wheelMake=Axis&wheelModel=MS&initialPartNumber=placeHolderFront&selectedRear=MS2110512040TG&wheelFinish=Titanium+Gunmetal thoughts anyone?
Yes, there are issues. The wheel will hit the suspension. You’re losing a whole inch of clearance on the inside. I run a 20x9 35mm offset which gives me 8mm less on the inside and I clear by just a bit. You will def hit. Plus, 245mm front tire would look awkward/super stretched on a 10” wide wheel. Super deal, but unfortunately will not work now that they ran out of the 9” wide fronts.
I considered the same wheel when both fronts/rears were available, but a) didn’t like how flat faced they were, and b) wanted to stick with 20” for range and more tire options. Was very close to just getting the set due to the extremely low price, though, but that’s kinda the point of a true clearance/closeout deal.
Hey Doanster, just to be clear, is the 8mm clearance just on your front tires with the 20x9? the 21x10 shouldn't be a problem on the rears correct? just want to make sure I understand.
Correct. 10” wide in the back won’t be an issue (assuming you’re not running some high offset). My 10.5” wide rears with 275mm tires are fine. I had slight rubbing on the wheel liner, not because of incorrect wheel/tire choice, but because the liners are deformed/bulge out due to Tesla only using a couple rivets/fasteners. I zip-tied the bulging sections back and easily clear everything now.
So I'm in the same boat and spoke to them for the 21" x 9 and 21" x 10s on my 100D Model S. They are saying confident there are no issues so wanted to see if anyone had additional thoughts.
Nice! Are those the same Axis Titanium Gunmetal rims? I have pearl white as well so hoping that's what it will look like.
Yup those are the Axis MS Gunmetal color. I was torn between that color and the lighter silver color.
